Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 03-12-2006, 14:31
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
Re: pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
Has anybody run into major problems so far with their ball-lock shifters?
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
Unread 03-12-2006, 15:26
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Originally Posted by jfelser
Yes, that is true about the model. The model is not quite correct in that the larger end piece of the inner shaft (the one attached to the cylinder) will be removable. The reason the shaft is two pieces is so that the larger spool will be centered with springs on the smaller inner shaft, which will allow it to lag a little when it pushes the balls outwards which make shifting easier.
Ok. Thaks for explaining.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 03-12-2006, 22:56
antoineft's Avatar
antoineft antoineft is offline
FRC #2609 (BeaverworX)
antoineft is just really niceantoineft is just really niceantoineft is just really niceantoineft is just really niceantoineft is just really nice
We used a 2 speed ball lock shifter last season and thought it worked out great. Assembly was a little annoying until we figured out that using grease to hold the balls in place while sliding the parts together works very well!
We also just built the plunger as 1 piece instead of using springs. This seemed to work pretty well because the air in the cylinder basically acts as your spring. I had the rookie kids this year pull apart the gearboxes to "get their feet wet" plus I wanted to see what they looked after a full season. The insides held up even better than I would have thought. The plunger definitely showed lots of tiny "dings" but is far from failure. We put it all back together and it still works great.
--Antoine
Unread 04-12-2006, 08:53
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Three years strong and I don't think we'll go to anything else....at least not in the near future. The concern Sanddrag has expressed about shaft wear and such is NOT a problem at all. We do measure sizes before and after season when looking at what we could improve and we have not discovered wear. This is simply because we harden the pieces we need to and keep a good amount of lubrication. So rather than posting something you DON'T know about from experience, maybe you should let the people who have built these talk about the down sides. I don't mean to start a fight with anyone, but I just can't understand how people who have not used these transmissions can discuss any problems with them. The biggest negative we've seen is these transmissions take time to machine with our team capabilities. You can make them with just a lathe and a mill. They are that simple, but having access to a wire EDM or a water jet would greatly help reduce the amount of machine time.
Great to see 948 investigating this design. Hope to see it on your robot this season! Good luck
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 04-12-2006, 11:32
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
Very interesting, indeed.
I am not familiar with the concept of ball lockup shifting gearboxes, indeed this is the first I have ever seem of them. I am in charge of developing a godd two-speed gearbox for '07, so here are my questions (more will follow after this) Your expertise and help is greatly appreciated.
I understand how the balls are pushed into slots in the gears, but what is it that causes the thus engaged gears to turn the output shaft? In a dog shifter gearbox, the dog is positively engaged on the shaft (still allowed to slide) and so whatever gear the dog is locked into thus turns the shaft. I cannot find any such mechanism in this drawing. Perhaps I am missing something, but I think this is an important consideration.
And, following that, what happens to the gear (with its ball slots) when it is disengaged and must freewheel on the output shaft? My understanding of the design at present leads me to believe that it would bounce and chatter considerably, possibly even locking the entire gearbox up if it doesn't properly disengage.
Just my thoughts, if someone can answer them, I would greatly appreciate it. Thank you in advance. -JH
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 04-12-2006, 13:16
AKA: Cliff Mock
The balls are what cause the engaged gears to turn the output shaft. Comparing this to a "dog shifter" the balls are your dogs. Half or more of the ball remains in the shaft and the other half goes into the slots in the gear. two things can happen when the balls are disengaged. They depend on the design. The original hodaka design had a small groove in the gear and used the balls to act like a ball bearing when not engaged this means the balls stick out from the shaft a couple thousandthsand the gear rides on the balls. For simplcity we have not put this groove in our design. As Brad stated we leave between 4-10 thousandths of air gap between the shaft and the gear. In our design the balls fall flush into the shaft. Then all we do is use a thin oil/grease mixture to lubricate the gears and shafting. The gears have some space to move on the shaft, but not as much space as it seems you are getting at. Also we have never had the transmissions jam up. I don't have time to look for it, but we have produced a white paper on this type of shifting and feel free to PM myself or team222badbrad with any questions.
Unread 05-12-2006, 03:45
team222badbrad's Avatar
Happy Birthday! team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
How The Ball Lock Transmission Works:
Ball Lock
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 05-12-2006, 20:53
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
Awesome video badbrad!! It explains the transmission very nicely. One question: How deep do the slots for the balls in the shifting gears go? A full 5/32? Or less than half of the bearing. It seems that slightly less would be the way to go, maybe 1/4 inch deep into the gear with a 5/16" EM (our design uses 5/16" bearings as well). I would think that the balls would disengage easier.
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Unread 08-12-2006, 14:38
AKA: Bradley Rigdon
Sorry for taking so long to get back to you.
How far the balls will protrude out of the shaft depends on the diameter of your "Ball Plunger" + two times the diameter of your balls - the diameter of your shaft.
If your plunger is .515" and your balls are .3125", then your slots must be atleast 1.14" from tip to tip. Each ball upon being "Locked" would travel .07" above the shaft if your shaft is 1".
1/4'' = VERY BAD!!! If your balls were to travel past halfway above the shaft your shifting transmission would then become a single speed or perhaps shred to pieces. The balls would become trapted between the gears slots and shaft because of the rotational forces you put on them.
This attachment should help you out.
77 thousands is plenty as thats what the motorcycle transmission I used in the video had.
Unread 18-12-2006, 21:18
FRC #0948
Ah, thanks very much for the warning!!!
There is a very good chance you'll be seeing a transmission like this on NRG's robot this year... we talked to our machine shop about it a week or so ago, and they were very optimistic about the design.
-Jake Felser-
Team 33's 2004 gearbox CAD files AdamHeard Inventor 1 03-10-2006 19:07
pic: My First time.....(CAD car drawing) negfrequency Extra Discussion 13 26-06-2006 23:12
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
