Go to Post I will gladly be pied if that's something you guys want. I know I have people from the Clarkson FIRST dorm floor who will shell out PLENTY of cash for the chance to pie me in the face! - Libby K [more]
Unread 06-12-2006, 13:15
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
OI switch input duplication
Hi;
I am trying to understand this section from ifi_aliases.h (~ line 50)
Ports 1 & 3 have their inputs duplicated in ports 4 & 2 respectively. The
inputs from ports 1 & 3 may be disabled via the 'Disable' dip switch
located on the Operator Interface. See Users Manual for details.
I looked for further reference in the manual, but I am not sure which
document I should be looking in.
Anyone have a better reference, or can say something more
about what "have their inputs duplicated" means?
What is it used for?
Unread 06-12-2006, 13:24
Re: OI switch input duplication
Lee,
A check of the OI manual will make things more clear. There is only so many inputs so IFI duplicated the inputs between the input ports 1-4. If you check the OI reference you will see a listing for each port and where it is mapped. This arrangment makes the OI more flexible for the user.
Unread 06-12-2006, 13:40
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
This whitepaper has exactly what you are asking presented very clearly. Hope it helps!
Unread 06-12-2006, 15:20
tux tux is offline
AKA: Lee Harr
So... "duplicated" means "wired together" ?
When the dipswitch is in the right position, there is no difference between pressing port 1 trigger and port 4 trigger. Is that right?
I thought I had all of the manuals, but I guess I never downloaded the OI reference. Trouble is, now I can't find any of the documentation on the new FIRST website. Anyone have a direct link to the docs?
I looked at the whitepaper/spreadsheet. It says:
Disable dipswitch near the bottom of the OI, allows the
disabling of trigger and thumb buttons for ports 1 + 3,
meaning that only the "same as" switches on ports 2 + 4
control the port 1 + 3 trigger, thumb, and aux buttons
So, flipping the dipswitch will make it so that only port 4 controls the value of p1_sw_trig?
Does anyone have a "for example" of how you might use this?
Thanks for your time.
Unread 06-12-2006, 15:29
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
IFI has most of the documentation you need for the OI I believe:
http://www.ifirobotics.com/oi.shtml
The reason for being able to do this is basically user convenience; if I hook up joysticks to ports 1 & 3, but need to use more inputs for my control system than is available from just 2 & 4, I can "steal" the inputs from 1 & 3. This saves me the hassle of having to build a special connector in between the joystick and competition port on ports 1 or 3 so that I could use their inputs.
Our team has done this numerous times, it can really be quite useful (especially when you're using 13 of your 16 digital inputs).
Unread 06-12-2006, 16:17
tux tux is offline
AKA: Lee Harr
Ah... It's all starting to make sense now!
Port 4 has access to BOTH sets of digital switches. You would need a customized controller in order to access the port 1 switches from port 4.
And the same between port 3 and port 2.
Thanks for the links and explanations!
User Input railerobotics Programming 4 29-08-2006 00:54
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Powered OI input EricS-Team180 Programming 7 28-09-2003 21:23
Graphic Input Raven_Writer Computer Graphics 7 08-08-2003 15:43
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
