Having a major problem w/ code!
For some reason i can not find this file!
![]() C:\Documents and Settings\Teh Pwnerer\Desktop\School!\Robotics\Pervious Years\2005\frc-code-1-12-2005v2.4\FrcCode2005v2.4\user_SerialDrv.c:30: unable to locate 'stdio.h' error 1 spawning c:\mcc18\bin\cpp18 Halting build on first failure as requested. where do i start first? mcc18? |
Re: Having a major problem w/ code!
First two things that come to mind:
naw dont wrry about it .. ima talk to a couple of ppl to get my set up w/ all the code cuz im soo confused w/ all these different ways of doing it
srry for the confusion |
You project location is way to deep
try moving your project to like c:\robotics\06\ and recompile, you cant go over like 94 characters or something like that [edit]sorry, didnt see mike already stated this[/edit] |
/forest |
... thanxs |
#7
"stdio.h" is common, abbreviation of Standard I/O. It includes things like printf().
#8
The problem is most likely that your MPLAB include path isn't configured correctly. We don't use MPLAB so I don't know where the settings are, but I'm sure somebody here will be able to help. |
#9
In MPLAB check
Project -> Build Options... -> Project then on the popup see if "Include Path" is set to c:\mcc18\h That's where stdio.h is to be found. Last edited by Mark McLeod : 09-12-2006 at 19:35. |
#10
I was having the same problem, and this completly fixed it! Thanks sooo much!
#12
I have to repeat this, try moving your project to a location like c:\code\06 if the path is too long you won't compile.
| Is anyone else having this problem | hpman247 | Programming | 10 | 27-11-2008 02:57 |
| Robot having internal heat problem | Gene | Technical Discussion | 24 | 08-06-2006 14:59 |
| Having a little problem with the camera... | capenga | Technical Discussion | 3 | 21-01-2005 10:54 |
| Major Inventor Problem | Chris Dibble | Inventor | 5 | 27-02-2003 11:12 |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 19-03-2002 19:44 |
