Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 07-12-2006, 21:58
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Having a major problem w/ code!
For some reason i can not find this file!
C:\Documents and Settings\Teh Pwnerer\Desktop\School!\Robotics\Pervious Years\2005\frc-code-1-12-2005v2.4\FrcCode2005v2.4\user_SerialDrv.c:30: unable to locate 'stdio.h'
error 1 spawning c:\mcc18\bin\cpp18
Halting build on first failure as requested.
where do i start first? mcc18?
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 07-12-2006, 22:06
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Having a major problem w/ code!
First two things that come to mind:
  • C-BOT (the compiler) has a 64 byte limitation on file names. Your path is quite large, try moving all the files into something smaller (I have C:\FIRST\Code)
  • Make sure that all the project paths are set correctly. I'm not too sure how to do this without having MPLab in front of me, but I'm sure if you search around you'll find an explanation.
http://www.mikesorrenti.com/
Unread 07-12-2006, 22:08
AKA: !!Mitch!!
FRC #1392
naw dont wrry about it .. ima talk to a couple of ppl to get my set up w/ all the code cuz im soo confused w/ all these different ways of doing it srry for the confusion
Unread 07-12-2006, 22:55
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
You project location is way to deep
try moving your project to like
c:\robotics\06\
and recompile, you cant go over like 94 characters or something like that
[edit]sorry, didnt see mike already stated this[/edit]
Unread 07-12-2006, 22:56
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
i'm no expert but could it be that you just speled something wrong? shouldent it be studio.h?
/forest
Unread 07-12-2006, 22:58
AKA: !!Mitch!!
FRC #1392
/forest
lmao ... possibly... im not too sure.. this is like last years code.. and the programmer graduated ... MAYBE! ... thanxs
Unread 08-12-2006, 17:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
"stdio.h" is common, abbreviation of Standard I/O. It includes things like printf().
Unread 08-12-2006, 18:00
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
/forest
NO!! It is definitely stdio.h.
The problem is most likely that your MPLAB include path isn't configured correctly. We don't use MPLAB so I don't know where the settings are, but I'm sure somebody here will be able to help.
Unread 09-12-2006, 11:41
In MPLAB check
Project -> Build Options... -> Project
then on the popup see if "Include Path" is set to c:\mcc18\h
That's where stdio.h is to be found.
Unread 09-12-2006, 17:27
AKA: !!Mitch!!
FRC #1392
Originally Posted by Mark McLeod View Post
In MPLAB check
yup i have that ... still getting that error tho... for now.. im just gonna get rid of it .... so that way i can work on some other stuff... if any could find out anthing plz let me noe
Unread 26-01-2007, 23:21
Plepel Plepel is offline
AKA: Chris
FRC #1877 (Gold Diggers)
Plepel is on a distinguished road
In MPLAB check
I was having the same problem, and this completly fixed it! Thanks sooo much!
Unread 27-01-2007, 21:26
abrockhoff abrockhoff is offline
AKA: Alex Brockhoff
FRC #0011 (MORT)
abrockhoff will become famous soon enough
Send a message via AIM to abrockhoff
c:\robotics\06\
I have to repeat this, try moving your project to a location like c:\code\06 if the path is too long you won't compile.
Is anyone else having this problem hpman247 Programming 10 27-11-2008 02:57
Robot having internal heat problem Gene Technical Discussion 24 08-06-2006 14:59
Having a little problem with the camera... capenga Technical Discussion 3 21-01-2005 10:54
Major Inventor Problem Chris Dibble Inventor 5 27-02-2003 11:12
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
