Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
Unread 08-12-2006, 16:21
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Re: Auto mode... need help
Originally Posted by Matt Krass
If memory serves it loops as fast as possible, so it could run anywhere from about 12ms to 26.2 and it will change depending on your autonomous code, if its really time sensitive, you should use the hardware timer, and its just good to know how to use that anyway.
No, that's the entire point. It doesn't loop as quickly as possible. It does its calculations and idles for the remaining part of the loop time. While I'm not at all sure about your robot being disabled if you don't get data within 26.2 ms, it could be true. However, no reasonable code for your robot would go beyond the 26.2 ms loop. You're not calculating pi to the 500th decimal place, you're not using the cubic formula, and you certainly shouldn't be using an loop except an iteration loop. Therefore, 26.2 ms is a safe figure by design.
Hope this helps,
Paul
10 ball auto mode nuggetsyl Scouting 22 27-02-2006 20:39
Sending variables to Auto Mode Adrien Programming 4 19-02-2006 21:51
auto mode nuggetsyl General Forum 12 13-02-2006 19:45
Auto mode help..... Moloch Programming 2 18-02-2005 09:18
Auto. mode!!! skitz547 Rules/Strategy 1 09-03-2003 22:37
