Go to Post This is definitely the best FRC parody of an FRC parody I have seen. - Jared Russell [more]
Unread 13-11-2006, 17:35
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Question Autonomous CMU Cam help.......
Ok all other problems have been fixed now im faced with the challenge of programming it. I am using a code from a thread i started about a year ago and ive adapted it to my program, when i run the bot in autonomous the cam doesnt do anything (ie. track or search) ive attached my program in a zip format can i get some one to over look it and see why its not working. Im also unclear on how to make it tell the wheels where to go in user mode. Thank you
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 13-11-2006, 18:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Autonomous CMU Cam help.......
Hello,
Some questions:
What other problems?
What code are you using?
Nothing is attached. (I cheated, thats not a question )
Have you looked over the How to ask a question thread?
-Mike
http://www.mikesorrenti.com/
Unread 13-11-2006, 18:53
AKA: Cameron Dennis
OOPS ........ here is the code, sorry about that.
www.frc1266.com
Unread 13-11-2006, 19:56
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
When your robot enters autonomous it does not leave until the autonomous flag clears. You must call the camera_handler, terminal, and tracking code must be recreated in the autonomous function.
If you add the same code you used in the Process_Data_From_Master_uP to User_Autonomous_Code it will work.
By user mode do you mean Autonomous or remote control?
Eric Haskins KC9JVH
Unread 07-12-2006, 18:23
FoxWil's Avatar
FoxWil FoxWil is offline
The world is mine!-Stewie Griffin
AKA: Fox
FRC #1646 (Precision Guessworks)
FoxWil is an unknown quantity at this point
Send a message via Yahoo to FoxWil
Quick Question: can you use the CMU Cam to track mulitple colors?
The death of one man is a tradegy, the death of a million men is a statistic.-Joesph Stalin.
Unread 07-12-2006, 18:48
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
The quick answer is no... While it can only track one color at a time (if you're using the track_color command, as I presume most people are), you could switch between more than one color by calling Track_Color each time so that you recieve feedback from the camera for each color that you're interested in, but I've heard that it takes too long for the camera to switch colors for this to be feasible
Unread 08-12-2006, 18:11
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
The CMUcam2 is incapable at the lowest level to track multiple colors at once.
And rapidly switching between two colors is quite inefficient.
CMU Cam Autonomy code? NEED HELP B4 FRIDAY! cdennisxlx2 Programming 4 08-12-2006 15:03
CMU cam Booger Programming 3 18-07-2006 00:00
CMU Cam on an EDU-RC Redneck Programming 2 11-02-2006 14:55
grrr need help with my cmu cam lilrican13 Programming 6 18-01-2006 00:14
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
