Go to Post My team does what works for my team. Let your team do the same. - Alexa Stott [more]
  #46   Spotlight this post!
Unread 23-11-2006, 03:12
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: What type of drive train is the most maneuverable?
Originally Posted by Joel J.
Is there a way to calculate the force (or torque, whatever) required to have a robot turn?
See this whitepaper:
  #47   Spotlight this post!
Unread 23-11-2006, 09:38
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally Posted by M. Krass
All other things being equal, a typical six wheel drive along the long axis will have a shorter effective wheelbase than a four wheel drive arranged on the short axis.
Uhhhmmmmm, not so fast there. As a general statement, this is not true.
It all depends on how you are going to define a "typical six wheel drive" and what assumptions and caveats you are putting on that definition. I will maintain that in a "typical" six-wheel drive, all six wheels are co-planar. In that case, the wheelbase of the six-wheel drive is established by the Conservative Support Polygon, which is defined by the four outer wheels. As specified in the original statement, the wheels are arranged along the long axis of the robot. The four outer wheels determine the resulting wheelbase, which by definition is longer than a four-wheel drive arranged along the short axis of the robot.
This fundamental truism is only modified if the definition of a "typical" six-wheel drive is altered to promote non-standard configurations. For example, the common practice of moving the middle pair of wheels into a non-planar configuration. On a hard planar surface, this causes the robot to ride on the middle set of wheels and one of the "end" set of wheels. Only four wheels support the robot, not six. Thus, the wheelbase becomes approximately half of the long dimension of the robot. But this is actually no longer a true six-wheel mobility system. It is a set of two four-wheel systems that share a common pair of wheels (the center ones). In this case, you lose many of the advantages of a six-wheel drive (ie. distribution of weight across more points of contact with the floor, greater stability across the longer wheelbase, etc.).
-dave
  #48   Spotlight this post!
Unread 23-11-2006, 14:11
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
-dave
Yes, this is entirely true -- and what I get for posting at 3 AM or some ungodly hour like that. In FIRST, I consider a 'typical' 6WD arrangement to include a lowered center wheel, but I can see that in another application, this definition would be incorrect. Trucks or airplanes, for example, may ride on six wheels rather four to, as you mention, better distribute their weight across a surface. I meant to speak only with the confines of FIRST use -- and even then, perhaps it's erroneous to assume that most consider the 'typical' 6WD arrangement to have a lowered center wheel.
--Madison--
...down at the Ozdust!
  #49   Spotlight this post!
Unread 23-11-2006, 15:37
Joel J's Avatar
Joel J Joel J is offline
do you..
Originally Posted by Jack Jones
I remember looking at that whitepaper. I recall that the only thing it said was that the length of the robot should be less that the wheelbase, for the robot to just begin to turn. I will look again to see if there is a method to determine how much force is required by a certain dimensioned robot, with a certain weight and a certain CoF with the carpet, to turn.
[edit: Ok, the equation is there. Great.]
Joel Johnson
RAGE (173) Alumni, 1999-2003
  #50   Spotlight this post!
Unread 23-11-2006, 18:37
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
All you students out there, read the post above, at least twice. There is a great lesson in it.
Many of the references (books, articles, poems, CD threads, etc.) that you will encounter will have more to say to you when you re-read them a season or two later. The reference doesn't change from one reading to the next, but you do. And you get smarter, or more experienced, or both.
Richard Wallace
since 2003
  #51   Spotlight this post!
Unread 08-12-2006, 20:36
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
I have read this white paper twice and I believe there is another factor to consider. The effective coefficient of friction in the lateral direction of a stationary tire is different (higher) than a tire that is slipping on the carpet.
We have had several successful skid steer robots with the wheelbase greater than the track width. These robots had large knobby pneumatic tires that were quite sticky. If the driver attempted to turn by energizing only the right side wheels and keep the left side stationary, the robot would not turn, as the white paper would suggest. If the operator pushed one stick forward and the other rearward with enough power to break the tires loose, the robot would turn. This was not a graceful turn, but worked well. This method requires the robot to have enough torque to break all wheels loose on carpet at the same time.
There is a good way to visualize this if you have ever driven on an icy road with a rear wheel drive vehicle. If you punch the accelerator and break the tires loose, the rear of the vehicle will move sideways as it slides down the crown of the road.
I cannot offer a formula to show this at this time, so I will have to leave the proof as an exercise for the reader.
Jay
  #52   Spotlight this post!
Unread 08-12-2006, 21:42
Retired
Originally Posted by Jay TenBrink
...I cannot offer a formula to show this at this time, so I will have to leave the proof as an exercise for the reader.
Jay
Dr. Joe's explained why here:
  #53   Spotlight this post!
Unread 08-12-2006, 21:57
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
The drive train that the students came up with a couple of years ago is a pretty good system. We have used it in OCCRA for 2 years now and for the altering of our FIRST robots, which is four wheel drive in the back with casters or skyway wheels in the front. We also tried slides in the front instead of casters but I like the casters better. It is a simple machine for your budget and is very dependable.
-Josh Murphy-
  #54   Spotlight this post!
Unread 09-12-2006, 22:09
Dick Linn's Avatar
no team (Synergy)
Ours was similar. The 4WD part had perhaps a 15 inch wheelbase and we used poly skids at the other end. Even so, the pneumatic tires were so grippy that steering was a bit herky jerky. Good system, though. Simple and reliable. he team won the Motorola Qualiity Award at the VCU regional for the overall 'bot.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #55   Spotlight this post!
Unread 10-12-2006, 09:04
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Originally Posted by Stephen Kowski View Post
On a tight budget? I'd have to go with a 6 wheel drive train with a lowered middle wheel. There are tons of examples of it done well here on CD, just search around CD Media.
I just did this yesterday for our test plateform. Just be careful about how much u lower the middle wheel. We used 3mm and it works great in carpet.
what type of shooter will be most common this year? gondorf Technical Discussion 16 16-01-2006 17:05
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
pic: team696 teaser of the Drive Train. xKLzKobE08x Extra Discussion 16 30-01-2005 22:59
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
What will be the most effective robot type this year Rick General Forum 8 13-01-2002 22:10
