Go to Post ah, common sense, not as common as one might think... - Ansem Retort [more]
Unread 10-12-2006, 08:38
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Question about programing the bumper sensors
easyC doesn't have a fast loop and a slow loop. Instead you program executes as fast as the processor can run it. Using a button on a interupt probably wouldn't get you anywhere.
When you do this:
while(counter<=50) //while the robot is driving backwards
Get_Bumper_Data(Back_Bumper_Port) /*puts the data from the back bumper into a global varaible named Back_Bumper_Data*/
if(Back_Bumper_Data==0) //if back bumper is pressed
break;
The code is probably looping in less then a ms.
Things to remeber when you write any code with high accuracy. MPLAB or EasyC Printing to screen kills your loop speed.
I don't know the size of rest of your code but as long as you don't have any prints or waits its probably cycling very fast. < 10ms
Lasty I think I would use a timer instead of a counter and keep reseting it.
We don't give you access to interrupts in easyC V2 for vex because we don't people stalling the microprocessor.
Unread 10-12-2006, 12:00
Gdeaver Gdeaver is offline
FRC #1640
Also, remember that no matter how fast the loop is or how fast you catch an interrupt, the user to master proc communications only happen on a tens of ms scale. This means that you can only affect a change to a vector every 10 - 20 ms. I forget the timing of the master interrupt in easy-c. I think it's different than the Mplab default code.
Unread 10-12-2006, 13:07
That's probably a good decision for somthing named "easyC", though I usually prefer to follow a different philosophy:
"UNIX was not designed to stop its users from doing stupid things, as that would also stop them from doing clever things." – Doug Gwyn
Bumper sensors jbill30 Programming 1 01-05-2006 18:49
Quick question about sensors..plz help thnx pheNIX637 Technical Discussion 6 30-10-2005 02:52
Bumper sensors jeffmorris FIRST Tech Challenge 1 02-10-2005 16:20
question on the pressure pad sensors Simon Strauss Rules/Strategy 5 08-01-2005 23:42
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
