Go to Post When I mentor other people in programming... they either get pointers or they don't. - JamesTerm [more]
Unread 11-12-2006, 22:52
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Standard vs. Custom Frame
I think a custom frame would be preferable if it is possible; but if you don't have the resources to pull it off effectively, and want to save yourself some time, the kit frame is definitely a good option. So many pre-drilled holes give you lots of nice places to bolt stuff onto (not that you need pre-drilled holes, as I assume your team owns a drill, but they're nice), and the frame is extremely adaptable, being able to fit most designs you can think of (cut a few frame pieces and you can make almost anything fit).
The only thing to worry about with the kit frame is strength and possibly weight; not strength from taking a hit and coming apart, but more from a mechanism or large amount of weight causing the C channels to start to collapse. We had to wedge a piece of extruded aluminum into the frame to keep it from folding in underneath our motor mount for our conveyor belt. Weight I suppose could be an issue, though we haven't had it be a problem yet.
Standard Joysticks EricWilliams Programming 26 01-04-2006 22:59
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
pic: Team 521 Custom Frame Steve P Extra Discussion 9 01-02-2005 11:19
Standard Operating Procedure K. Skontrianos General Forum 7 01-03-2003 14:02
Developing a standard Jack Scouting 23 03-01-2003 23:04
