Go to Post Totally agree on the fact that legal strategies are... legal. - Kevin Sevcik [more]
Unread 12-12-2006, 21:25
Dylan Gramlich's Avatar
Dylan Gramlich Dylan Gramlich is offline
Christian group in FIRST? Ideas?
FRC #1126 (SparX)
Team Role: Tactician
Dylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond repute
Send a message via AIM to Dylan Gramlich
Re: 6WD chain path
do this and it will be simple yet effective.
take a few pieces of paper, cut out pieces for your wheel and trans. then place them on the ground like how you will mount them. then take string and mock it up as chain.
that should help you out.
2005-2008: Student Mechanical and Strategy Lead
2009-2010: Mechanical Mentor
2011-2013: Strategy and Field Team Mentor
Unread 12-12-2006, 22:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 6WD chain path
The best way to do this is have the Dewalt gearboxes direct drive your center wheel axles by means of flexible coupling (I recommend aluminum 3 jaw spider couplings made my Lovejoy and sold through Applied Industrial). Then just run a chain from the center to the front, and from the center to the back, on each side. If you have to, you can really drive any wheel from the Dewalt, but the centers are preferable because they are always in contact with the ground (if the center wheels are offset relatively lower than the rest). If you have to space to do it, you should avoid having 6 chains. It is more potential failure points.
EDIT: I missed the "total of four" thing
Unread 12-12-2006, 22:32
Billfred's Avatar
Billfred Billfred is offline
Re: 6WD chain path
Last year, 1293 did 6WD off of the Kit gearbox. We ran two chains off of the gearbox, one to the rear wheel and one to the center wheel, which then ran a chain to the front wheel. Worked beautifully--even when we threw chains from balls riding into the frame (a problem we fixed with bolts), we never threw enough chains to immobilize ourselves.
Unread 12-12-2006, 23:09
in between teams
AKA: Luke Van Oort
Re: 6WD chain path
In our 2006 'bot we used 6WD drive with the KOP tranny and frame. Our robot had its gearbox between the center and rear wheel with two chains, the "interior" one ran from the tranny to the center wheel, then front, then back to the tranny, the "exterior" one went to the center, then rear, then back to the tranny. There is a picture on the robot's FIRSTwiki entry that might help make sense of my description. The upshot of this layout was, with just two chains, we achieved pretty good redundancy, and any one chain could drop and maintain 5WD (really 4WD) capability, which was handy several times.
Team 1219: 2009 - Mentor
Unread 12-12-2006, 23:22
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: 6WD chain path
Direct drive the middle wheel from a live axel, and run chain out to the other two, that way... no single chain failure can cost you an entire drive side. The only downfall is that you have to make custom hubs for the middle wheels.
In the below diagram... the blue is the chain, the black rectangles are the wheels, and the yellow boxes are the Dewalt Trannys. The middle wheel would be driven by the grey box, which is the live axel... The outlying wheels would be driven by chain and ride on dead axels.
Edit: I know that this would only use two of the motors... but it would be very easy to go with a setup like the one below as well:
You would just need to machine more hubs...
White Paper Discuss: Dr Joe's Chain Path Visualizer Joe Johnson Extra Discussion 10 24-11-2008 18:31
6WD? Alex Cormier FIRST Tech Challenge 14 17-04-2006 22:10
Inventor file path help Rickertsen2 Inventor 3 08-04-2006 12:54
FIRST On A Disturbing Path DCaldwell05BCP General Forum 69 15-04-2003 14:58
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
