Go to Post The Scouting Award exists. It's called "Championship Winner". - Chris is me [more]
Go Back   Chief Delphi > Other > VEX
Unread 12-12-2006, 20:05
Dylan Gramlich's Avatar
Dylan Gramlich Dylan Gramlich is offline
Christian group in FIRST? Ideas?
FRC #1126 (SparX)
Team Role: Tactician
Dylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond repute
Send a message via AIM to Dylan Gramlich
downloading problems.
I am having problems downloading programs into the robot. The issue is when i go to dl the program it says something along the lines of com port 1 something.
Also has anyone seen my long lost battery from the ruckus? it says DYLAN on it by the way.
2005-2008: Student Mechanical and Strategy Lead
2009-2010: Mechanical Mentor
2011-2013: Strategy and Field Team Mentor
Unread 12-12-2006, 21:30
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: downloading problems.
I have no experience with VEX, but "com port 1" would be the serial port easyC would be trying to contact the VEX controller through. Try selecting the other options--like I said, I don't know anything about VEX so I can't instruct you how to do this. If present, try the "Auto-select" option.
Good luck, and hopefully someone who knows something about VEX replies here.
JBot
Aren't signatures a bit outdated?
Unread 12-12-2006, 21:47
FRC #1126 (SparX)
JBot
well thanks, we solved that problem. the enxt problem is getting it to have a steady orange light so it will dl.
Unread 12-12-2006, 23:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you are using EasyC, all the Vex Controller needs to do to be able to download code (AFAIK) is just be on. As long as you have the correct COM port selected, when you download code it should just interrupt and stop any programs running on the Controller. To the best of my knowledge, I don't think I've ever even seen a solid orange light on my Controller. The only orange light I've ever seen is just that one that blinks every now and then on the inside of the Controller case.
I've never had any problems downloading code to the Vex Controller that couldn't be solved by either a fresh battery, the correct COM port, or the just turning it off and then back on again.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-12-2006, 23:23
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
well we had talked to some others. and was talked through the port problem. with this steady ornge light ting is unheard of. It goes withsomethign like: hold down the programming button untill a steady orange light appears and it will dl.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 12-12-2006, 23:35
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I use VEX, and I never do anything except plug in the cable, and click download(and change the COM port).
If your using IFI loader you will often need to do a controller verification if the last controller you used was not a VEX, but I've never had any problem with Intelitek.
Eric Haskins KC9JVH
Unread 13-12-2006, 12:05
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
We had the exact same problem. First, check to make sure you have easy C version 2.8.1
If you do, try different computers and different usb ports. We found that only certain usb ports worked for dling program. It was very strange. I think only high speed usb ports work, but I can't confirm that.
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 13-12-2006, 12:10
AKA: Eric Haskins
When you are using a USB/Serial adapter the COM port assigned to the adapter will be different for each USB port.
You can look in the Windows device manager under serial/parallel ports to find the COM port # of that adapter on that USB port.
Eric Haskins KC9JVH
Unread 13-12-2006, 12:32
FRC #1405
Hmm, i was trying to dl it from my toshiba laptop, same usb each time. i should try any of the other two usb ports then.
Unread 13-12-2006, 13:03
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
If you go into loader setup, it will show the available com ports.
I like to take the USB to serial adapter and assign it to the same
com port for all my USB ports. You can reassign them in device manager.
If you need to reinstall the driver its listed on http://www.intelitekdownloads.com/FVC2006/
Also try turnning off verify in loader setup.
Problem downloading code Romeo1351 FIRST Tech Challenge 6 01-12-2006 06:33
Wild motors while downloading GlennGraham VEX 2 22-09-2006 19:52
Downloading code to 2005 RC Eclipse Control System 2 23-02-2006 19:58
Downloading LabVIEW Apps kevindur National Instruments LabVIEW and Data Acquisition 6 01-02-2006 02:50
Beginner problem with downloading pagemauck Programming 2 17-01-2004 13:24
