Go to Post KISS does not mean that your goals and capabilities are "simple", it means that the way you achieve them is simple. - jspatz1 [more]
Unread 15-12-2006, 09:19
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
Problem with the 2005 controller
Hi again...
I'm faced with a very strange problem. We have built a new driving system and we want to check it. For that I took the 2005 robot controller and hooked it up to all the necessary things. I downloaded a program to see that it works properly with the RC. The weird thing was that The radio receiver stayed in STANDBY state, and wasn't working properly. I thought it could be that the receiver or the program has some sort of a malfunction, but when I connected the receiver to the 2006 controller it was working fine, with the program I tried to download to the 2005 controller.
I then noticed that there was another problem with the controller. It looked as if it were stuck at programming mode. The Program State LED did not blink and stayed orange, and the 3 lower LEDs were not blinking nor making any light at all. I think there is something wrong with the controller itself.
Has any of you faced such problem before? Is there any solution to it?
Thanks,
Guy
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Unread 15-12-2006, 09:41
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Problem with the 2005 controller
Did you have it teathered when you first downloaded the program?
Unread 15-12-2006, 09:51
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Sounds like the OI and RC are set to different channels. Teather the controller then try it.
It could also be a code error. "If you get the red light of death" check to see if you have the correct library file.
Hope this helps.
200th Post!!
Eric Haskins KC9JVH
Unread 15-12-2006, 14:53
FRC #1574 (MisCar)
The code has certainly no problem because it worked on the 2006 controller. I'll try to tether it to see if it helps. Another thing I noticed was that when I pressed the RESET button, it was as if I pressed the PROG button, meaning that the controller was initialized after I pressed RESET
Visit our website:
www.miscar1574.com
Unread 15-12-2006, 15:41
Originally Posted by Guy_E View Post
The code has certainly no problem because it worked on the 2006 controller...
Are you aware that the 2005 and 2006 Robot Controllers use different microprocessors? If you're trying to run a 2006 program on a 2005 controller, it's quite reasonable for it to get confused. You should probably recompile the code with the proper library file and appropriate target CPU selected.
From the Using_Last_Years_FRC.txt file included with the 2006 default code:
To compile this project to work with your 2005 FRC (18F8520) system do the following:
  1.  Select the correct device from the MPLAB IDE.
      Configure->Select Device->PIC18F8520
  2.  Replace the library file with the appropriate one.
      Remove the FRC_Library.lib file and replace it with FRC_Library_8520.lib
                                        or
      Remove the FRC_alltimers.lib file and replace it with FRC_alltimers_8520.lib
  3.  Remove the 18f8722.lkr file and replace it with the 18f8520.lkr file
  4.  Rebuild your project and download the HEX file to your controller.
Unread 15-12-2006, 15:57
FRC #1574 (MisCar)
This might be the solution to my problem. I'll do that on Sunday when I get to see the controller again.
Thanks.
Visit our website:
www.miscar1574.com
Unread 15-12-2006, 18:01
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Yes today i had the same situation! .. thats what i thought... something wrong with the MPLAB hex file created.. worked with other controllers but that 1
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 17-12-2006, 02:02
FRC #1574 (MisCar)
I switched the files, but still, it didn't make any change. The controller still seemed to be stuck and the LEDs weren't blinking. Do you know what could possibly cause it?
Visit our website:
www.miscar1574.com
Unread 17-12-2006, 12:21
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Tether the RC and OI. Plug the OI into the wall. Download the default code. Check the OI dashboard (set OI to RC mode). Does the 2005 default code work? Do any errors appear on the dashboard?
If that works, try again with your program recompiled for 2005. Does your code work? Do any errors appear on the dashboard?
Is it just me, or does this seem to be a recurring problem?
Unread 17-12-2006, 14:38
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Also you might want to try a master reset. This disables the user processor and allows you to download programs in the event of a problem preventing the user processor from accepting downloads normally. If you can't get the light out of program mode you could have this issue.
Hold down both RESET and PROG buttons for ten seconds. Then release RESET and hold PROG for another ten seconds, then release. It should result in a power light, and an orange program light and nothing else. I think. It's been a while, if that doesn't work, trying releasing PROG after ten seconds and holding RESET for ten more, it's one of those two I think
Matt Krass
Unread 18-12-2006, 01:38
FRC #1574 (MisCar)
Thank you so much! It really helped and solved my problem.
I pressed RESET and PROG for 10 sec and than continued to press RESET for 10 more and than all the LEDs returned to blink normally.
Thanks,
Guy
Visit our website:
www.miscar1574.com
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with Lowering the Bar Kevin Kolodziej General Forum 14 12-01-2004 21:58
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
The problem with scouting... archiver 2001 10 23-06-2002 23:49
