Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 15-12-2006, 23:23
Re: Rounding numbers
Originally Posted by teh_pwnerer795 View Post
int i = 1;
static int time_i;
i=i+1; // This will increment 'i' by the value 1 every loop
time_i = ((i * 262) / 10000);
I believe you have declared the wrong variable as static. The way it stands now, i will be set to 1 then incremented to 2 each time through the loop, and time_i will always be computed as 0. If you change it to say
static int i = 1;
int time_i;
instead, i will remember its value between loops and be incremented as desired, and time_i will do as neilsonster said...
...at least until 125 loops have occurred, after a bit more than 3.25 seconds, after which time (i * 262) will overflow and you'll start getting negative results.
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Part Numbers DDRAngelKurumi Kit & Additional Hardware 1 29-01-2005 18:38
Random Numbers Astronouth7303 Programming 9 18-01-2004 21:39
Team Numbers archiver 2000 2 24-06-2002 00:24
Numbers at VCU Madison Regional Competitions 5 10-03-2002 02:26
