Go to Post Nutritionally speaking I didn't get enough (MOE) green in my FIRST diet this year! - Mark McLeod [more]
View Poll Results: which do you like better?
Hex 12 38.71%
Dead 14 45.16%
Other 5 16.13%
Voters: 31. You may not vote on this poll
Unread 16-12-2006, 11:57
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Hex vs. Dead axle
Ok, me (being new just last year) has to figure out what the pros/cons are to each of these set ups... also what the hex set up really is!
last year, the kitbot was appropriately set up to do what I know as a dead axil... where there is a bolt of the appropriate dimentions bolted to the chassis, and the skyway wheels have their berings on that bolt... and the sprocket is bolted to the skyway. Pretty sure we aren't animateing the axil here.
Now comes this Hex boar from andymark, and some mention of hex driven drivetrains or something. Elighten me!!!! Please?
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 16-12-2006, 12:32
Billfred's Avatar
Billfred Billfred is offline
Re: Hex vs. Dead axil
So far, so good.
Basically, hex shafts (and round shafts with keyways) are both forms of live axles. With live axles, your bearings are held in pillow blocks to allow the shaft to rotate. This way, for example, a sprocket doesn't have to be physically connected to a wheel to transmit power. This can yield some advantages in maintenance if you design correctly, and live axles can be cantilevered, where a bearing is not the outermost element on a shaft. (Look at the drivetrains of 254/968/60/22/4/980, and you'll see what I mean).
The big advantage that hex shafts have over round shafts with a keyway is that the hex shaft is the key--power is transmitted in six places, as opposed to the usual one or two with a keyway. It also means you don't have to fish for a new key when your original breaks...but generally at a higher cost, if you've got to broach your own. (1/2" hex broaches are by no means cheap.)
Unread 16-12-2006, 12:33
REVving up for a new season
FRC #2848 (All-sparks)
http://www.chiefdelphi.com/forums/sh...ight=dead+axle
fyi: when people use hex it is just a form of a live axle, check out that thread, everything you need is there.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 16-12-2006, 13:40
CraigHickman
Posts: n/a
We used dead axels last year, and got sort of aggrivated. So this year we're going to switch to live axels, but not in the form of hex, as we don't have a hex broach.
As far as breaking a key... If you can break one, I'm not too sure you're distributing your load properly...
Unread 16-12-2006, 16:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Yeah, the advantage doesn't come so much in not having to worry about breaking keys. It's that you don't have to worry about having keys. You just slide the wheel on the shaft and go.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-12-2006, 19:58
GMKlenklen's Avatar
The "Masonater"
cool thanks guys!
Thank you,
-of the MASMabots-
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
axle problems illumanat'i Technical Discussion 8 02-02-2003 02:01
Axle mounts- Chain tensioning Jeff Sharpe Technical Discussion 12 20-01-2003 22:50
axle thread size archiver 2000 3 23-06-2002 22:50
