Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Unread 16-12-2006, 20:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
pic: FVC Team 228 at the 2006 ConnVex Event
Unread 16-12-2006, 20:26
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: FVC Team 228 at the 2006 ConnVex Event
Excellent Robot from 228 I rate it (without knowing its performace) a solid 9 a couple questions though:
What gear ratio did you use in your drivetrain?
Could it climb the platform?
Did it only score in the high goal?
What kind of mechanism did you use to get the balls up to the goal(an elevator perhaps)?
And Possibly more questions to come....
-Dustin
-Dustin Benedict
Unread 16-12-2006, 22:51
Synergy1848's Avatar
Synergy1848 Synergy1848 is offline
Vex Career: 84-20-1
AKA: Tony
FRC #1848 (SOUP)
Synergy1848 will become famous soon enoughSynergy1848 will become famous soon enough
it appears as though the wheels are 1:1 with a 4 motor drive. but i dont know. did you quallify for champs?
FRC# 1848 Team Soup
2007 Peachtree Winner 2008 Peachtree Imagery Award Winner
Mr. Roboto and Super Pals
2005 FVC 24 finalist, 2007 FVC 2024 NC winner, Champs 3rd seed; semi-finalist
2008 FTC 3 Tn Winner, Inspire award, Motivate award Ga Finalist, Amaze award Champs '08 Franklin
Unread 16-12-2006, 23:54
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Team 228 was eliminated during the Semifinals against the alliance of 839, 2160, and 2013 (IIRC, 2013 were captains, but I missed alliance selection).
The finals were then 40, 2078, and 3197 (again, IIRC, 40 were captains) vs them, and the Team 40 alliance ended up winning in three matches.
Here is a picture of the rankings bracket. There were only 6 alliances, which is why you see gaps in the QF's:
As for championship eligibility, obviously the winning alliance qualified, but I do not remember who won the Inspire Award.
Team 177 - Bobcat Robotics
Unread 17-12-2006, 10:24
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
I'll answer some technical questions here.
It is a direct drive, 4 motor drive train. We thought it would be a little too fast and difficult to control, but the speed definitely worked for us after a little practice. We were clicking off the clutches in some turns, but we're not going to change it.
To tractor the balls off the ground, we used the small wheels to roll the balls around a curved backplate. Balls then rolled into an upper hopper, which could hold 4 balls. Two more balls could be held in the two independently driven rollers, for a total of 6. We would dump 4 at a time into the high goal, then re-load the other two balls and immediately re-dump.
The upper hopper is lifted with with 2 motors, and uses a continuous chain arrangement to power it up and down. We doubled up the chain to increase its strength. IFI's linear slides are used to achieve the smooth movement.
Our ground clearance is 1.5", which easily gets us on to the platform. Though, we don't hang (yet...) Our strategy is focused on scoring balls in the high goal and gaining control of the atlas ball.
Feel free to ask more questions. Hopefully, we'll have more pictures up on our website soon.
BEN
Unread 19-12-2006, 19:28
Justin O'Keefe's Avatar
Justin O'Keefe Justin O'Keefe is offline
FRC #1983
Justin O'Keefe is on a distinguished road
Dude thats the most bad $@#$@#$@# idea ever with the balls pulled up by wheels
TEAM #1983
and Drummer of "Chromatic Death" (Death/Black/Goregrind)
Unread 19-12-2006, 23:45
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
BEN
I appeciate your willingness to answer questions!
Looks like the largest size chassis kit?
What's your motor count/use?
I see 4 on wheels (4") direct drive
2 as pair? for elevator,
1 for lower roller,
1 for upper roller?
What is the ball pickup mech, I see tank tread.
Looks like the small wheels used for ball roller have their tires inside out;
thats the first time I've seen that, did your team think it up or see it elsewhere?
What is the most activity done during Autonomous mode, just dump the preload, or any line-following or random driving? There is mention of scoring 3 balls in autonomous mode, but I thought the rules were no more than 2 balls per robot? Did you take a handoff from your partner?
Thanks, I'm looking forward to more details at the website.
Unread 20-12-2006, 00:08
Bengineer
I'd be more than happy to answer some more questions. It's not quite the largest chassis size. It's a 25x25, though we are exactly 18" high!
Motor count is at 8 right now.
- 4 for the drive
- 2 for the elevator
- 1 each for the intake rollers (the kids found it was easier to position the stored balls with seperately powered rollers)
For the ball pickup, we use a couple different devices. The outboard intake roller is a single tank tread pulley with the tank tread wrapped around it. This wheel is mounted on a rear-mounted swing arm, and can move up and down to adjust to varying sized balls (or the stitching on the ball.) We use chain and sprockets to run this roller off the 1st impeller motor. It's sped up, but not by much.
We then used the rubber 2.75" wheels, but turned the tread around so that we could, again, adjust for varying size balls. The curved walls that we walk the balls up are mounted at the top of their arc, and float on the bottom. We use the vex-legal elastic bands to pull the bottom of the arc, which keeps tension on the ball as it's walked up the arc. We've seen systems similar to this on FRC robots, but obviously nothing on a FVC bot.
Our Auto-mode is still being tweaked, as we weren't totally happy with it. Yes, you can only start with two balls, which we load in our hopper. We elevate the hopper and dump the balls in about 2 seconds. We then lower the hopper, drive forward and pick up one more ball from the pile in front of us. While the balls works its way up the intake wheels, we back up to the goal. Once the ball is in the hopper, we elevate and dump the 3rd ball. At the moment, it's all done by timing loops, which we had to tweak over and over to get it right. For our next comp, we'll probably have encoders and bit more tweaking done.
However, the three balls in Auto wasn't even close to what Team 40 was putting up. I'll let them post their auto-mode (and robot description) if they'd like. They're the main reason we want to improve our auto-mode.
I'm waiting for the pictures too! Keep an eye out on the Connvex.org website as well. There should be some pics there soon. Hope this helps,
BEN
Unread 20-12-2006, 06:53
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Your wish has been granted. "Poof"
http://www.checkmate40.com/Video/Connvex06/
Unread 20-12-2006, 22:29
AdamHeard's Avatar
Lead Mentor
Can you give us a description of how your robot is actuated. I get the jist of the mechanisms from the videos, but can't tell exactly how you did it.
Unread 21-12-2006, 07:02
Kingofl337's Avatar
AKA: Adam
The kids used tank treads as chains (stronger) and fixed a link of tred to the basket.
The rest works the same as the tank tread would on the floor. Except with
a fixed anchor point, when the chain spins it lifts the basket. 2 motors
provide the power to get the job done and a little extra in case they want to
lift something heavy in the future.
Unread 21-12-2006, 07:52
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
Lots of photos posted at http://www.connvex.org/?page=gallery with more to come!
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 21-12-2006, 08:33
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
How many balls can it hold? What was the average amount of balls other teams could pick up?
Unread 21-12-2006, 14:04
Kingofl337's Avatar
AKA: Adam
We can hold 7-8 balls pretty easy, we can hold 2-3 in the intake and 5-6 in the top hopper.
To me the avarage was about 2 balls.
Sorry to hi-jack your thread Art If you would like
I can create a new thread.
Unread 21-12-2006, 23:04
amystolting amystolting is offline
FRC #0228 (GUS)
amystolting will become famous soon enoughamystolting will become famous soon enough
Thumbs up Re: pic: FVC Team 228 at the 2006 ConnVex Event
Sooooooooo Cooool.
ConnVex - FVC Championship Tournament - Hartford KathieK FIRST Tech Challenge 10 31-12-2006 01:18
Thank you to FVC 228, The Vexperts! KathieK Thanks and/or Congrats 0 06-10-2006 11:40
pic: Team 228 - 2006 Teaser #1 artdutra04 Extra Discussion 20 26-01-2006 08:32
pic: Team 228 in VEX: Part 2 artdutra04 Robot Showcase 7 15-09-2005 18:00
pic: Team 228 and the floating tetra artdutra04 Extra Discussion 8 02-05-2005 19:58
