Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 16-12-2006, 21:59
Billfred's Avatar
Billfred Billfred is offline
Riveting up a frame
(I searched "rivet" and didn't find anything, so here goes.)
So I know that there are those of the riveting school of thought, at least when it comes to your frame. I'm looking at the option of riveting up the kit frame next year (assuming it's the same and blah blah blah), as it seems to be an easy way to both drop some weight (albeit less than welding, but with the advantage of easier repair) and cut out the issue of locknuts backing out.
This leads to a few questions in my mind:
1) Are rivets a viable option for an average FIRST robot frame?
2) What kind of rivets are best for this? Aluminum is the cheapest option, but stainless steel rivets have higher strength by orders of magnitude.
3) If you've riveted the kit frame, is it best to just put rivets everywhere the bolts should go, or can you do well with less?
4) Is there anything in particular to look for in the way of damage after the robot has taken a few hits?
Unread 16-12-2006, 22:06
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Riveting up a frame
That actually is a good idea in the beginning, however, from personal experience rivets break easily especially under strain, also if you use rivets you have to use washers to allow the rivet to grab and hold the metal together. Once again they are very weak and in a match if someone hits you your frame might break apart.
Championship - Delphi "Driving Tomorrows Technology"
Unread 16-12-2006, 22:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Don't do it, unless you find some really large rivets.
Unread 16-12-2006, 22:36
DonRotolo's Avatar
Back to humble
FRC #0832
Rivets are weak in shock load, but great for static loads.
A loose bolt is much weaker under cylical loads than a properly tightened one (ask the Mech Engineering guys why). A rivet (of the type you are considering) cannot be 'tightened' - the tightest you can get it is not very tight. (Rivets for big steel, like the GW Bridge, are installed hot, so they shrink and 'tighten'). So, loose rivets and cylical loads equals premature failure.
Also, the rivet starts to get loose quickly, and it's ability to be strong* drops significantly. That means instead of tightening up nuts and bolts, you get out the hammer and tighten up the rivets.
*Strength doesn't actually change, but a loose member has a little bit of distance available to allow it to build up some momentum before it hits the end of the rivet...and that isn't good.
Don
[Edit: The above refers primarily to standard peen-over rivets, not Pop Rivets mentioned by Deepwater]
Unread 16-12-2006, 22:37
Billfred's Avatar
Given the kit frame's quarter-inch holes, I'm looking at McMaster 97525A553 (stainless steel) or 97447A652 (aluminum), or the other rivets of similar size. Bigger than what I'm accustomed to, but I don't know what qualifies as really large these days.
Unread 16-12-2006, 22:59
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
See this post in this thread. Contrary to chakorules opinion we had excelent success riveting the KitBot chassis last year.
So I know that there are those of the riveting school of thought, at least when it comes to your frame. I'm looking at the option of riveting up the kit frame next year (assuming it's the same and blah blah blah), as it seems to be an easy way to both drop some weight (albeit less than welding, but with the advantage of easier repair) and cut out the issue of locknuts backing out.?
We riveted the KitBot chassis last year and had ZERO problems, ZERO lost rivets, and ZERO failures. We went all the way to the finals at our one and only regional (Colorado) and only lost by a few points in the last match. We found a riveted KitBot to be very strong and effective. We will probably do it again this year unless something drastically changes.
1) Are rivets a viable option for an average FIRST robot frame??
Absolutely! They are cheap and effective. They can easily be drilled out if needed and do not weaken the frame like welding. They save a significant amount of weight over nuts and bolts and there is no chance of the nuts loosening and falling out. They are simple to install after you do one or two and get the hang of it and are actually much faster than nuts and bolts because you don't have to hold a wrench in a hard to reach location.
2) What kind of rivets are best for this? Aluminum is the cheapest option, but stainless steel rivets have higher strength by orders of magnitude.?
We used .25 diameter aluminum rivets with an aluminum mandrel. Specifically MSC item #04045431 - $7.06 per hundred. You will need a couple of boxes. You will also need a rivet tool that can handle 1/4" revits. The small ones you get at the local home store won't cut it. We used MSC item #74327552 - $93.91. The tool is a little expensive but works and was the least cost tool I could find that would handle 1/4" rivets. Buy it once and it will last for many seasons.
3) If you've riveted the kit frame, is it best to just put rivets everywhere the bolts should go, or can you do well with less??
We basically replaced the 1/4" nuts and bolts in the KitBot with 1/4" rivets. We put them in the same holes plus or minus a few where we attached our roller pillow blocks and upper ball holder frame. We also riveted diamond plate to the KitBot frame. You could probably do with less rivets but they really don't weigh much each so it isn't a big loss to put a few extra in. If you properly rivet the KitBot frame together replacing each of the 1/4" bolts with a rivet you will have a very tight, strong, and durable frame and save more weight than you think. When you get your kit this year open up the KitBot box and put those two little bags of nuts and bolts on a scale and see how much they weigh. IIRC it was almost 2 lbs. If you put a nut and bolt in each hole as instructed you won't have many left over.
We never had a problem with damaged rivets. We were a big target and got into a lot of pushing and smashing matches. Our 0.020" diamond plate got smashed a bit in places but our rivets and the KitBot frame are still just as good as the day we put it together during the first week after kickoff last January.
Any other questions just let me know. I have to give two thumbs up to a properly riveted KitBot!
Unread 17-12-2006, 01:00
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
In one of the prototypes, I believe team 1114 used quarter inch steel rivets and it worked great for them. See this thread.
Unread 17-12-2006, 01:10
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
I know that 1126 rivets their aluminum frame together instead of welding it. Right Dylan?
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 17-12-2006, 10:08
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
We riveted our upper frame last year (1/8" aluminum riveted w/ 1/8" aluminum rivets) and it worked pretty well, but as someone already mentioned, rivets don't take heavy shock well.
Also, repairs can be a bit tricky. We found that in most cases it's easier and faster to add more rivets than to replace the old ones, which is fine if you're using small rivets, but on the kit frame, you'd need some big ones. (We didn't rivet our drive base.)
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 17-12-2006, 12:10
Gdeaver Gdeaver is offline
FRC #1640
Team 104 has used 1/4" steel rivets with back up washers since 2001 except the stack attack when we tried a 8020 frame. We have never had a riveted joint fail. For 2006 we bolted the kit chaise together and when the design became fixed backed up the bolts with rivets. We built up the kit frame with 1" 6061-t6 angle. The frame worked just fine.
Unread 17-12-2006, 12:17
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Team 1501 uses a frame completely made from sheet aluminum and pop rivets. You will not find a stronger frame.
http://www.huntingtonrobotics.org/
Unread 17-12-2006, 12:23
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Im pretty sure welded steel is a bit stronger...
As for rivets, I would use them in the less vital area's, but not for heavy frame rails. They dont react to shock very well, and could also reak havok on the field with wheels and drivetrains if some were to come loose.
Just my 2 cents. If you can make it work you get a High 5.
Unread 17-12-2006, 12:44
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
FRC #0399 (Eagle Robotics)
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
I am from a team where we usually only rivet our robot no welding. We have never had rivets break if you use the aircraft quality. these can take up to 26,000 lbs of shear force, only cost a couple dollars for a 1/4 lbs of them, and come in varying sizes. We find it is also safer than welding because we the students do almost all of the work. These are not pop-rivets though if that was what you were referring to.
Unread 17-12-2006, 13:00
AKA: Matt Howard
Why cant students weld?
Unread 17-12-2006, 13:22
clean399's Avatar
Mr. Clean
AKA: Nick Hayes
Most students we can trust to do work like that but there is those few who don't know when joking around should not be done. Also riveting is a lot easier to learn how to do rather than welding.
Stock Frame... Herbie698 Technical Discussion 21 11-03-2005 20:16
Frame Dragging Wetzel Math and Science 0 22-10-2004 17:10
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
Playing Field Frame reisser 3D Animation and Competition 27 06-02-2003 22:29
