Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - ATannahill [more]
Unread 17-12-2006, 13:26
President, VEX Robotics, Inc.
Re: Riveting up a frame
We used rivets in 2005 and 2006 and those were our best robots, by far. We used 1/8" aluminum rivets with aluminum mandrels in most places, but 1/8" aluminum rivets with steel mandrels in places where we could not use a lot of rivets, but needed strength. Our entire drive base, main structure and end of arm in 2005 were riveted sheet metal. Our entire drive base, tower, and shooter frame in 2006 were riveted sheet metal.
Anyone who says the rivets are not strong enough have either not used it, or implemented the rivets improperly. Strength to weight ratio is out of this world and I will race anyone changing out a component riveted together vs. bolted together. Our riveted components can be repaired and replaced much faster with rivets than with nuts and bolts.
Using 1/4" rivets in the kit frame should prove very effective. Also remember, you want to have a mechanical fuse when it comes to collisions. We usually do not have the weight to design our components against severe crashes/mishaps, but the rivets will break in key areas in order to save components.
Unread 17-12-2006, 13:28
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Originally Posted by clean399 View Post
Most students we can trust to do work like that but there is those few who don't know when joking around should not be done. Also riveting is a lot easier to learn how to do rather than welding.
Personally, I find it alot easier to lay a bead then riveting, but to each his own.
and who cares if it works.
Dylan Gramlich's Avatar
Dylan Gramlich Dylan Gramlich is offline
Christian group in FIRST? Ideas?
FRC #1126 (SparX)
Team Role: Tactician
Dylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond repute
Send a message via AIM to Dylan Gramlich
Originally Posted by Starke340 View Post
I know that 1126 rivets their aluminum frame together instead of welding it. Right Dylan?
yeah thats correct we used rivets this year more then any previous year and we were quite happy with how it held up.
2005-2008: Student Mechanical and Strategy Lead
2009-2010: Mechanical Mentor
2011-2013: Strategy and Field Team Mentor
Unread 17-12-2006, 13:42
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
I would have to agree with Dylan on this one.....we were really happy with the way our framae held up during all the matches. Our robot even got flipped over for the first time in finals at nationals and it still was in tact.
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 17-12-2006, 20:30
jagman2882 jagman2882 is offline
former driver, now mentor
AKA: Cory Gramlich
FRC #1126 (SparX)
jagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura about
Send a message via AIM to jagman2882
we did use rivets but it was mostly in the upper frame around the shooter and such...i dont think that we would ever use them on the driveframe...but i think that they did hold up quite well. but again you must be careful where they are place and the amount of stress.
2003-2008 Match record 132-59-1
'04 Newton Division Champ, '06 Galileo Division Champ
'03, '04, '08 Buckeye Champs, '07 Finalist
'06 Finger Lakes Champs, '08 Finalists
'08 Buckeye Motorola Quality Award
'07 Buckeye General Motors Industrial Design Award
'05 Buckeye Radioshack Inovation in Control award, '06, '07 Finger Lakes Rockwell Automation Innovation in Control Award
Unread 18-12-2006, 09:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
177 Uses POP rivets in similar ways to what Paul said above for 217. We also use solid aircraft rivets installed with a pnuematic hammer and bucking bar in application where higher shear strength is needed or if we need the rivet to be flat headed. We have made arms capable of lifting a robot of the ground this way using aircraft construction methods. Needless to say we believe the strength is there.
A word of advice if you plan on using big diameter rivets is to get a pneumatic tool for installation. Particularly if you use a lot of them.
Just a general comment, we find a mixture of joining using welding, rivets, rivnuts, and nut/bolt fastening depending on the application gives us the best solution for the problem. Don't rule out any of these methods unless you are not properly equipped to do them.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 18-12-2006, 16:58
Generator of Entropy
FRC #2973 (The Mad Rockers)
Interesting discussion - good question Billfred. I'm surprised to hear the amount of success using rivets and the kitbot, especially using backing washers. Normal design practice for rivets - at least in my work experience - is to avoid tensile loading and just use them for shear loading (obviously they have some amount of tensile capability, but they aren't designed for it) Installation involves match drilling close fit holes - I would think that the kitbot standard clearance holes are nowhere near adequate to get a good interference fit after bucking or popping. Has anyone run any calcs or tested tensile load capacity?
S.P.A.M. (I can't say 'we' anymore) has used rivets very successfully on some structural components, but not the chassis. Definitely the lightweight solution if you can make it work.
Unread 18-12-2006, 19:29
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
What do you call a 747?
A million rivets flying in formation!
Back in the days when Northrop Grumman was just plain Northrop, we built the fuselage for 747s. We also installed 3/4 of those million rivets. (Actually I think it was 995,000 but at that point who's counting?)
In modern aircraft structure rivets are often used for joints that are never intended to come apart. Just walk down the F-18 line with me sometime and listen to all the rivet guns, and just why do you suppose hearing protection is required in all the assembly areas?
Used properly, rivets are a very practical fastening method, but they have to be done right to work. That means matching the rivet diameter and length to the hole, countersinking to the correct depth for flush rivets, and using the proper mandrels and riveting tools. But if it is good enough for a modern fighter aircraft if ought to be good enough for a FIRST robot.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 19-12-2006, 00:16
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We use 1/8" rivets EVERYWHERE.
See how to link here:
http://www.huntingtonrobotics.org/in...d=1&Itemid =2
Or Video here:
http://www.huntingtonrobotics.org/in...=1&key=1&hit=1
The whole frame is "ribbed" and "skinned". Just like an airplane is made. No need for welded steel. It does get "dented", but it never has "failed" on us yet. Even the wheels are riveted with bulkheads and quite strong.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 19-12-2006, 00:22
Controls Engineer
AKA: chakorules
Originally Posted by DeepWater View Post
See this post in this thread. Contrary to chakorules opinion we had excelent success riveting the KitBot chassis last year.
What is this pick on chakorules day? LOL ;-). I didn't get a chance to respond to myself in that post. I meant, kitbot and rivets don't mix well because we don't normally use the kitbot frame, we make our own frame. I didn't mean it as it "reads" like we used rivets on the kitbot frame. We have never tried that to my knowledge. We always use the bolts and normally we use the kitbot to build a proto-type frame to the programming team, that's where I come in. I don't think I've ever even used the pop-rivet gun yet in three years on the team, woooo.....I am gunna get it for saying that....
Favorite CD quote:
Unread 19-12-2006, 00:24
AdamHeard's Avatar
Lead Mentor
I went on a tour of some production lines and was amazed at how many rivets were being used.
Unread 19-12-2006, 00:36
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
FRC #0456 (Siege Robotics)
Nah, I didn't mean it that way. I guess my sense of humor didn't come through on that one. I guess I was trying to point out that I tried to start this very discussion about riveting KitBot frames back then but nobody seemed to take the bait at the time.
Unread 19-12-2006, 19:49
JessR JessR is offline
#0571 (Team Paragon)
JessR will become famous soon enough
We have aluminum pop riveted some assemblies with excellent results.
A good design practice is to use a splice plate or gusset plate at connections between two structural members & install multiple rivets in each member.
For instance at a right angle connection between two tubes, put a triangular gusset top & bottom with 4 rivets thru the gusset plates into each tube.
This also spreads the load over a larger area of the frame tubes, reducing the likelyhood of exceeding material yield at a single concentrated point if using one rivet.
A 3/16 rivet is the same size as a #10 screw. Holes are easy to drill and they are plenty strong for anything on a FIRST robot if using multiple rivets at a joint.
1/8 rivet are great for adding small plates for limit switches etc. or reinforcing structures after it's all bolted together.
2004 UTC New England Champions with 716 & 230
Engineering Lead
Team Paragon #571
Stock Frame... Herbie698 Technical Discussion 21 11-03-2005 20:16
Frame Dragging Wetzel Math and Science 0 22-10-2004 17:10
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
Playing Field Frame reisser 3D Animation and Competition 27 06-02-2003 22:29
