Re: CMUcam initialization time
Based on testing (in easyC) the reset time is about 2 seconds. Which would be fine as long as the colors don't change rapidly. Like if you had to pickup an object that was blue and drop it off in the green square. That would be fine as long as you reset the camera right away. Hopefully they don't use red or blue as the robots might go after the LEDs on the side of the robots. But, that may be why they went to flags last year.
They'd also have to ditch the drop lights in the alliance station. Given that those aren't just decorative (they're status lights for the robots--when the light is flashing, something is wrong), I don't think they would do it.
I would personally like to see an updated firmware for the CMUcam, like people say it takes a few second to change color parameters on the fly.. i have a hard time believing that this is a hardware problem causing this huge delay
i toaly agree with u on that 1 .. im pulling my hair out half the time when my camera doesnt boot up properly.. which is really strange cuz its stops the master thing to stop working as well:S:S werid! .. anyways .. i've been able to switch colors just not in 2 secs ![]() |
Not if those drop lights were the vision targets themselves. If the goal was positioned right in front of the driver's station, then you would be able to use them just as regular lights. They might have to add diffusers, and maybe tweak the field controller code a bit, but they could become active elements themselves.
Does anyone know if the cmucam's firmware is opensource?
#7
No, it is not, but if you Email the CMUCam developers they might share it with you.
#8
My guess would be probably not. Based on their site:
http://www.cs.cmu.edu/~cmucam2/downloads.html the firmware looks closed-source. They offer .hex files for those who have access to an SX-Key programmer to upgrade the firmware. I would guess it would take a lot of reverse-engineering to write custom firmware for the CMUcam. You might consider firing off an e-mail to IFI just to see what they have to say about it. JBot |
| Possible bug in memory initialization? | eugenebrooks | Programming | 3 | 08-04-2006 09:22 |
| Search Servo Initialization Caution | Keith Watson | Programming | 3 | 09-02-2006 07:49 |
| initialization program and speed controllers | rosebud | Programming | 15 | 05-10-2004 03:35 |
| Reciever Initialization problem | PuiChi | Programming | 1 | 26-01-2004 23:54 |
| Master uP Initialization Routine | Ulibrium | Technical Discussion | 5 | 24-01-2002 16:43 |
