Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 17-12-2006, 15:31
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
Problem getting started with USB 6009
I have installed everything per the instructions, and can talk to the USB-6009 using the Measurement & Automation Explorer. However, when I try to use the Instrument I/O Assistant in LabVIEW, I get an error dialog telling me that Measureent & Automation Explorer or the Instrument I/O Assistant is not installed correctly.
I looked again at the installation program and didn't see anything missing. I looked for related options in the LabVIEW settings and didn't see anything.
Has anyone else had this problem? Any ideas to fix it?
Thanks,
Jim Greenhaw
Unread 18-12-2006, 09:15
AngelaM AngelaM is offline
AngelaM is an unknown quantity at this point
Re: Problem getting started with USB 6009
Hello Jim,
First, you probably want to be using the DAQ Assistant rather than the Instrument I/O Assistant to communicate with your USB-6009. The Instrument I/O Assistant is designed to work with GPIB/Serial and most other devices with which you would use NI-VISA to communicate. The DAQ Assistant will help you get started in communicating with NI-DAQmx devices, of which the USB-6009 is.
Ultimately, if you do desire to use the Instrument I/O Assistant to communicate with other devices, then I recommend that you uninstall and re-install the Instrument I/O Assistant from the Device Driver CD. It is possible there was a corruption on the initial installation.
I hope this helps. Please post again if this resolves your questions or if this resolves the behavior for you.
Regards,
Angela
National Instruments- Applications Engineer
Important note about USB-6009 input voltage limitations jerry w National Instruments LabVIEW and Data Acquisition 7 11-01-2006 13:09
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
Getting Started with Scripting LBK Rules Programming 2 15-01-2005 01:28
Getting Started Cheese Head Programming 4 09-10-2002 22:24
