Go to Post Life has its Ups and Downs, you can stay down or push yourself. - Mike Schroeder [more]
Unread 18-12-2006, 16:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Standard vs. Custom Frame
Originally Posted by M. Krass View Post
  • It's difficult to discern what components are custom-made and which are off-the-shelf. Is there particular use or reason behind the elaborate pillow blocks? They're complex to machine and their length through bore seems excessive, making the cantilevered load on each axle much further from the frame than it need be.
I believe that those are off-the-shelf bearings. They look similar in size and proportion to the needle roller bearings 116 used in 2005.
Check out our cannon bot! Salik Syed Robot Showcase 28 14-01-2006 15:42
New old server - Check it out sanddrag Website Design/Showcase 22 07-03-2005 19:51
Check out our new site(prepare to be wowed) D. Gregory Website Design/Showcase 32 02-03-2003 21:12
Our website uses php-nuke. check it out! xxlshortys Website Design/Showcase 1 21-01-2003 19:43
