Go to Post We know that the real goal of FIRST is not for this robot to win, but that we learn something. If i was on robotics to win, it wouldn't be nearly as fun. - Nin_estarSaerah [more]
Unread 14-12-2006, 23:30
Sh00kaL00k Sh00kaL00k is offline
AKA: Shahrukh
FRC #1396 (Pyrobots)
Sh00kaL00k is an unknown quantity at this point
Send a message via AIM to Sh00kaL00k
batteries and chargers
hey everyone,
Build season is coming up soon and my team is pretty psyched.
There is one problem we are having though.
We are trying to find a way to charge 3 or 4 batteries at the same time. Is there a heavy duty battery charger out there we can use? Our battery charging system is insufficient for our needs, so we are looking for a new method.
If anyone has any information on things such as chargers, charging methods, wire maps, or anything of the sort, it would be greatly appreciated.
Thanks again
-Shahrukh
Unread 14-12-2006, 23:38
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: batteries and chargers
I would suggest you read the following threads from here, here's a link to them
http://www.chiefdelphi.com/forums/sh...ad.php?t=49603
http://www.chiefdelphi.com/forums/sh...attery+charger
This is a fleet charger that was discussed in those threads.
http://www.interacter.com/X5_page.htm
http://www.batteryweb.com/interacter.cfm
I hope this helps. We would have loved to have something like this ourselves, but it's out of our budget.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 14-12-2006, 23:48
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
  • You might want to check out this old thread that I dug up, discussing charging multiple batteries at once (from the same charger)
  • There are companies out there that sell chargers that are meant to charge multiple 12 volt lead acid batteries at once, these chargers are for different models than the ones we use, they would still charge the batteries from the kit.
  • Check the rules from year to year to see if you can use systems like so
Unread 16-12-2006, 01:21
AKA: Dr. Brooks
no team (WRRF)
I would like to strongly discourage the practice of hooking up
multiple batteries in parallel to charge them. Although the
bucket of water analogy has some degree of validity for healthy
batteries, hooking batteries in parallel can have dangerous
consequences in the presense of a battery with a shorted cell,
or should the batteries be hooked up with the wrong polarity.
The safest path is to use an automatic charger, with a current
limit of 6 amps, individually for each battery to be charged.
Knowing that in spite of my reccommendation some teams
will wire batteries in parallel to charge them (I see this in the
pits every year), please make a custom wiring board with fused
anderson connectors that limit the current to each battery to
6 amps if you plan to do this. This will not cost much
money and will prevent hooking up batteries with the polarity
reversed. It will also provide protection in the event that a cell
shorts in one of the batteries.
Please note: I am not suggestin that you exceed the 6 amp
current limit on the charger, replacing this limt with fuses,
as this would be against the rules...
Eugene
Unread 18-12-2006, 08:10
Hooking batteries in parallel to charge them is a fruitless way to go. There is only one right way to charge multiple batteries and that is with a multi charger designed for multiple batteries. Although lead acid batteries do not require sophisticated chargers, the charger provided in the kit and several available in retail or online are "smart" chargers. These "smart" chargers alternately supply charge current and monitor or even slightly discharge the battery to determine charge state. A smart charger will not only limit the maximum current but will charge your battery in the most efficient and shortest possible time. Placing batteries in parallel for any reason, is a sure way to shorten battery life.
Failure to follow electrical rules (or any safety related rules) in the pit is a sure way to get your team in trouble.
Unread 18-12-2006, 17:29
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
The only way to (safely) charge multiple batters on the same charger is to use a special charger that is intended for that purpose. Normal chargers don't supply enough power to charge more than 1 battery at a time, and the wiring to split the current could also get a little tricky.
Charging battery's too fast is REALLY bad for the battery, it causes some of the cells inside it to short. That's why these super-heavy-duty chargers are hard to come across, and I won't recommend using them.
Best thing to do, in my mind, is use multiple chargers, 1 to charge each battery. On my team, we have about 12 competition batteries, and 12 chargers. This works, but it is expensive to buy 12 chargers. Also, with rumors of FIRST getting new batteries this year, it might be best to wait and see what batteries they get.
Unread 18-12-2006, 20:33
Ok let's sum some points up here:
  • Yes, it is possible to charge a battery quickly
  • Yes, it is possible to run other configurations safely
  • Yes, it is possible to charge multiple batteries at once
  • Yes, it will damage your overall battery life.
Moral of the story? Be patient and protect your investment. It's not worth the risk of charging a battery really fast for one match and then having it kick out completely on you later in the day (when you really need it)
Unread 18-12-2006, 21:30
AKA: Dr. Brooks
no team (WRRF)
Given the propensity of dangerous jury rigged battery charging setups, perhaps it is time for FIRST to have specific rules requiring the use of anderson connectors on battery chargers, and one-to-one hookups between batteries and chargers. If the rules are specific they will have to be followed...
Eugene
Unread 18-12-2006, 22:35
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by eugenebrooks View Post
Given the propensity of dangerous jury rigged battery charging setups, perhaps it is time for FIRST to have specific rules requiring the use anderson connectors on battery chargers, and one-to-one hookups between batteries and chargers. If the rules are specific they will have to be followed...
I would like to see such a rule.
Richard Wallace
since 2003
Unread 18-12-2006, 23:02
REVving up for a new season
FRC #2848 (All-sparks)
ditto. Those uninsulated alligator clips are very close together when you clip them into the Anderson connectors, and I have witnessed arcing many times in the pits and even my own shop.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-12-2006, 08:04
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Eugene
I think this may all ready be a rule. Because we were a rookie team we borrowed chargers from parents on the team and at one of the tournaments they had us tape andersom conectors to them.
Unread 19-12-2006, 08:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It's not a rule, but like they said above, it ought to be.
The trouble is finding Anderson SB50 connectors with the right contacts for the smaller-gauge wire in a battery charger, or making a good splice using the 6 AWG leads on the ones you're given. Actually, I think B.G. Micro had the correct connectors at one point. And you can always order them from Terminal Supply or another vendor.
Unread 19-12-2006, 09:58
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Second this notion. We bought an X5 a few months ago......it charges 5 batteries at once...comes with Anderson Connectors and has only 1 power plug!!!!!
The unit was about $400....that's less than the $100 a piece you pay for kit chargers.
X5 Charger
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 19-12-2006, 16:06
I like the rule and recommend this method to whoever will listen. You can make an adequate connection to the charger leads if you strip the insulation back about two inches and fold the wire several times to increase it's diameter. This method followed by a good soldering job will make good connection.
To quell any false hopes, fast charging a gell cell battery with anything other than a smart charger at 6 amps or less will not give you a full charge no matter how much current you try to push into the battery. Shortened life is only one problem that you may encounter, explosion and pit damage is another. If you choose to try and bypass acceptable charging methods, please do not come to a FIRST event.
Unread 19-12-2006, 16:19
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Originally Posted by Sh00kaL00k View Post
hey everyone,
Thanks again
-Shahrukh
Your best bet is to use individual chargers. Also, put andersons on the end of the chargers to keep one from arc welding in the pits!
Batteries and Shipping Windward General Forum 3 19-02-2006 00:16
Batteries and hard impacts ConKbot of Doom Electrical 1 19-02-2005 13:39
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
Crate and Batteries Phil Paspalas Technical Discussion 3 08-02-2005 14:17
MMH and Batteries Plus Order Forms Posted Justin Stiltner FIRST E-Mail Blast Archive 3 28-01-2004 09:59
