Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Unread 19-12-2006, 12:27
CE Mexican CE Mexican is offline
FRC #1783
CE Mexican is an unknown quantity at this point
Question About Gear Boxes
Hello my name is Chris Evans I am head of drivetrain, along with frame & structure for Team 1783 The Firebots. Recently I have designed a three speed gear box, and I need a little bit of help as far as how to make the transmission shift, and what to use as far as gears? Any help with this would be greatly appreciated.
Chris Evans a.k.a. Mexican
Unread 19-12-2006, 12:33
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Question About Gear Boxes
I have only ever seen 2 speed gear boxes, is there a reason a 2 speed wont work?
Unread 19-12-2006, 12:36
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Check the whitepapers section and search the forum for information on gearboxes. I'm especially fond of the 222 ball lock shifter .
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 19-12-2006, 13:15
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Chris,
Welcome to the technical world of CD. You should be able to find more information than you know what to do with here. Just be sure to search before you ask...
Now, I find it ironic that you've been able to design a 3-speed transmission, but don't know what gears are in it or how it shifts. Maybe you could elaborate a bit on your preliminary design, how you came about this design, etc... If you have any sketches, feel free to post them here. As Cliff pointed out, there are a few two and three speed designs listed in the whitepapers section.
I think we'll need more details before we can help you with your design.
BEN
Unread 19-12-2006, 13:47
Billfred's Avatar
Billfred Billfred is offline
You forgot the four-speed.
Historically, transmissions have been shifted one of three ways:
1) Pneumatic cylinders. These are relatively cheap, easy to install in most cases, and they have enough oomph to them to get the gears shifted. Problem is, that requires a pneumatics system, which adds both weight and complexity to the robot.
2) Servos. Servos are cheaper still, can be put in a middle position (good for shifting the DeWalt three-speed transmissions) and don't require any added systems, but they sometimes don't have enough force to do the job. And your programmer will have to do some fiddling to find the right value to use for each gear.
3) Motors. Teams will use a kit motor (the Globe motor seems to be a common choice) to turn a rod to shift the gears. This is sometimes preferable over pneumatics, but they may be a little slower to shift, and you have to add feedback of some other sort (encoders, switches, etc.) to make sure the motor's keeping the robot in gear. Of the three, this is generally the least common in my experience.
Each has their highs and lows, which only you can evaluate as it pertains to your design. Hope it helps!
Unread 19-12-2006, 15:14
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It would certainly be helpful if you could describe in a little more detail what kind of gearbox you designed. There are several methods to shifting. Most FIRST transmissions are either mesh or dog shifting mechanisms (search around the forums and whitepapers for more detailed descriptions), but there have also been ball and pin shifters that a few teams have used. I suggest surfing around the forums a bit more, and perhaps even communicating with some individual teams. You may want to investigate Team 33's 2004 4-speed mesh shifter, 45's dog shifters (or its cousins the AndyMark shifter and AndyMark servo shifter), 222's ball shifter, 254's (or the many teams who have adopted variants of its drive) pin shifter, or the DeWalt transmissions used by many teams (such as 469).
Gear Boxes team_1373 Motors 4 25-07-2006 00:19
pic: gear boxes Kyle A Robot Showcase 18 23-11-2005 18:44
gear boxes BoticsPUNK General Forum 6 24-01-2003 20:35
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
Gear Boxes Keithicus Technical Discussion 3 21-01-2002 23:22
