Go to Post Our robot will use sensors to collect information about its environment, then discard that information and drive into a wall. - Jared Russell [more]
Unread 18-12-2006, 13:48
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Re: New CVT technology
The Yonge-CVT website provides a lot of really good information about CVTs. Including descriptions and critiques of other CVT technologies, such as the NuVinci and Anderson CVTs.
Unread 18-12-2006, 14:13
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally Posted by Viper37
The same is true to robots. Sudden collisions or load on the drivetrain would reak havok on a CVT tranny.
Actually, sudden collisions and rapidly changing dynamic loads are exactly why you would want to use a CVT for an application like a FIRST robot.
Follow the load path for a typical FIRST robot with a traditional gear train providing power to the wheels (or treads or whatever). When the robot slams into a wall, or rapidly goes from forward to reverse at full speed, the shock load transmitted through the gear train will be significant and can be enough to cause failure of the drive train. Examination of a number of case histories has shown that the in the vast majority of cases (better than 95%), the weak point in the system is in one of two places. If the gear train is designed properly, the failure mode will be a loss of traction between the wheels and the ground, and the wheels will just spin in place. Annoying, but not fatal.
But the other frequently seen mode is when the wheels do not break free, and the entire shock load is transmitted through the gear train. All too frequently this results in broken gear teeth and a trashed transmission requiring extensive repair or replacement. This is because the gear teeth tend to be the weakest points along the load path. Unless specific precautions are put in place (ie. designing primary failure points with shear pins, properly calculating tooth face width to increase load tolerance, etc.), the result is that a gear is turned into a disk. This failure mode makes up the vast majority of transmission failures that are seen at FIRST events (other than the problem of having the silly wire clips fall out of the Bosch gearboxes and causing them to drift into neutral that was a big problem a few years ago, but fortunately we don't have those any more, so the less said about that situation the better).
Alternately, the failure mode in a CVT is a non-fatal event. The load path between the input and output elements is across an intermediate friction drive (based on the design, either balls, rollers, disks, or splines are used as the intermediate elements). When the system is over-loaded, the friction in the drive system is overcome, and the elements slip in relation to each other. In the worse case, there will be surface wear on either the intermediate element or the torque plates which may shorten the overall lifetime of the drive. But it is not a catastrophic failure, and a properly designed CVT will have wear compensation adjustments built in that will enable the CVT to continue operating.
This is exactly the sort of capability that you want to have on a robot that is going to see repeated severe shock loads. In a situation where you have a choice between a traditional gear train and a CVT, and both have been properly designed to withstand the same loads, and you know/suspect you are going to have dynamic shock loading situations that exceed the load ratings of the transmission, then selecting the system with the non-fatal failure mode would be a prudent choice.
Ever repaired one? I have, and it wasnt a pleasant experience.
Yes, I have repaired one. I have also designed one from the ground up.
-dave
Unread 19-12-2006, 22:51
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
What type of CVT was it?
Also, since you seem to know quite a bit about CVTs, is there a way to make one that is hard-linked (i.e. not friction based)?
Thanks!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 20-12-2006, 00:42
CraigHickman
Posts: n/a
CVT's are a very interesting propostion. I have heard of some planetary kind in passing, but never got a chance to hear/research more on it. Does anyone know what at all I could be talking about? It has something to do with the speed of the outside ring gear...
As far as on a FIRST bot, I think it would depend entirely on the game, and the weight of the module. If I could take 10 pounds off by having a single speed, and instead use the 10 pounds on a scoring method, I would. If the module were light enough, It very well could be worth it in the long run.
Unread 20-12-2006, 08:37
Rob2713g's Avatar
Thanks!
The Yonge-CVT is hard linked. It is definitely a unique design and seems to be very well researched and thoroughly documented. You can even read his development journal. It looks a little complicated and big for a FIRST robot, but it would be really cool to prototype it.
The main page of his site has links to how a high speed and regular speed CVT would work.
What new technology will FIRST have this year? Michael Hill Technical Discussion 23 13-11-2006 16:47
NEW Science and Technology Council Jay5780 Robotics Education and Curriculum 2 12-04-2005 19:54
XPrize People Set Up New Technology Competition Joe Matt Chit-Chat 3 09-10-2004 16:46
New Military Technology sevisehda Chit-Chat 0 16-09-2003 04:58
CVT Clark Gilbert Chit-Chat 10 11-05-2002 19:38
