Go to Post Perfection is less about effort or skill than it is about having a clear and limited goals. - SoftwareBug2.0 [more]
Unread 19-12-2006, 16:35
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
What we have learned about Batteries
My Dad and I got all of our 12V batteries togeather, and measured the voltage on them as they charged with the chargers FIRST provides us. Over the course of a few weeks we accumulated quite a bit of data.
We put all of our data into a spreadsheet and now use it to approximate battery charging times. Hope this helps anyone who reads it!
It can be found here.
Unread 19-12-2006, 17:03
Re: What we have learned about Batteries
Did you proper battery load tester when testing, or did you measure with a volt meter? Without a realistic resistance, your voltage measurements will approach the EMF of the battery, and not the actual voltage it is able to supply. I ask this because your readings look near perfect and theoretical.
Unread 19-12-2006, 17:05
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
177 did some testing on their batteries last year. I don't have the actual data, but we found that a few of them were very nice, and a few were not so hot. We ranked them in order and saved the good ones for tough matches. We had an actual battery load testing device that we purchased, but I am not sure of its exact specifications. If you want more information, PM me, and I will try to find it.
Unread 19-12-2006, 17:22
AKA: Matt Howard
We load tested.
Unread 19-12-2006, 17:26
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
A few questions
  • How much load did you test?
  • How did you come up with the fact that 14.20 volts is a full charge?
  • How old are all of the batteries? Are they all the same age?
  • Are they all the same model?
Nice information though, it could be useful, I'd just like to see how you back up your results (I worked in a lab experimenting with LiNiO2 batteries).
Unread 19-12-2006, 20:51
AKA: Matt Howard
Originally Posted by Conor Ryan View Post
A few questions
1. I dont know how much we load tested, I was in and out, my dad took care of that.
2. We measued each battery after it had been fully charged. 14.20 was the average I believe after a full charge with no load.
3. The batteries are 2 from each season, seasons 2004-2006.
They are all the same model I believe.
Like I said, it is an approximation and nothing is a substitute for a good old volt meter.
Unread 19-12-2006, 20:57
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
Now, this is newsworthy in and of itself, though I'm not sure how much of it is true.
*Apparently* FIRST is moving away from the Exide ES18-12 battery, and moving to a battery by MK (the ES17-12). This came from the Batteries Plus vendor when I tried to confirm some information about ordering new batteries (as we were going to order more for this coming year).
I don't know anything other than that -- I tried to follow up with the FIRST "KoP Engineer", but they did not return my call.
Again, this is ONLY from the battery vendor "Batteries Plus", and I HAVE NOT been able to confirm any battery changes and/or official vendors yet.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 19-12-2006, 21:49
Matt,
Interesting data and a great visual on how the battery charger works. As you will note in all the batteries, the charging voltage is a minimum when the charge current is at maximum. This is a great display of how the battery changes impedance with the charge. I am guessing you were monitoring the charge current with an ammeter inserted into the lead between battery and charger. Although the current appears to be pure DC it is in fact pulsing. This accounts for the slight differences between batteries for specific currents at specific voltages. It also accounts for the apparant high terminal voltage near the end of charge as the battery impedance gets higher, the voltage drop inside the charger become less, so the peak voltage rises to near 14 volts. (13.8 volt theoretical for a lead acid battery) The phenomena you noticed when the LED changes state is the portion in the charge curve when the charger begins a "delta" check on the battery. This alternating cycle is the charger taking a look at the difference in battery voltage under a slight load. The charger samples the battery voltage as it looks for a reduction in change over time. As a lead acid cell nears full charge it will continue to draw current but the terminal voltage rises at a different rate. As you can see in the graphs, the sudden upturn in charging voltage signals that the battery is nearing full charge, yet it continues to draw current. At this point, most of the charging current is being turned into heat as little or no additional chemical reaction can occur. Of particular interest is the fact that the battery is listed as a 12 volt battery yet produces 14 volts at full charge. This is phenomena is known as "surface charge" and it will disappear after a short period of time or under load. Although this testing shows that all your batteries are taking a charge at roughly the same current, it does not give an indication of how the battery acts in discharge on a robot. Load testing vs. time is a good indicator of the condition of your batteries in practice. Thanks for all the info. Can I use this in a presentation some time?
Unread 19-12-2006, 22:11
AKA: Matt Howard
Use away! I would be glad to know someone is using it for good!
One thing I forgot, we drained the batteries not by using a load tester, but by affixing 5 lamps to the batteries, and draining them down over the course of a day. THe actual testing was done the same way, but with a single lamp i believe.
Unread 19-12-2006, 22:49
AKA: Dr. Brooks
no team (WRRF)
The chargers provided in the KOP are not three stage chargers. This is clearly demonstrated in the data collected in the first post in this thread. A three stage charger charges at a constant current until a specific voltage is reached, and then maintains this voltage for a specified time before kicking down to a lower voltage to maintain the battery. A three stage charger recovers more charge quickly due to the initial constant current, and provides a more complete charge through the absorption step at a constant voltage. If you are going to invest in additional chargers to maintain your pool of batteries, you should consider a true three stage charger if your goal is the best battery performance possible.
Eugene
Unread 19-12-2006, 23:12
AKA: Dr. Brooks
no team (WRRF)
More reason to wait until we see the game rules and KOP before buying equipment and supplies that may be affected by the rules!
Specification sheets available on the net put this battery at the same size, weight and capacity* as the EXIDE ES18-12, so this possible change would be transparent, except for the possibility of ruling out use of prior year's batteries for competition matches. Lets hope not. Some teams have acquired quite a collection of batteries, over the years, and carefully maintain them.
* Some web sites list it as 18 amp hours, and some list it as 17 amp hours.
* Some web sites list it with a maximum discharge current of 90 amps, for 5 seconds, instead of 230.
Any change is possible, we won't know until we see the KOP...
Eugene
Unread 20-12-2006, 12:17
The original batteries were speced at 17.2 Amp Hours several years ago. 18 AH was likely the marketing department trying to boost sales. Be careful, although BA is telling you it is the battery, it might just be their cross reference to the actual battery. Rule of Thumb, don't buy anything until kickoff. Murphy is in full force!
What have we learned about design? Rick TYler Regional Competitions 0 04-03-2005 21:08
What I Learned In FIRST This Year... Andy Grady General Forum 58 13-06-2004 08:27
What I have Learned in FIRST RBrandy General Forum 21 12-05-2004 15:59
HELP - We have no batteries!! Rick Gibbs Championship Event 3 24-04-2002 19:07
October Sweet Repeat II: Lessons Learned about 2 v 2 skrussel Off-Season Events 8 18-07-2001 18:15
