Go to Post Do you know how, say, Native American cultures were kept? They had storytellers, sages, and the like. They passed on their legends and culture to the next generation. So will we. - EricH [more]
Unread 08-12-2006, 22:12
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
Re: Martians 494 cvt pics
This CVT is a one of a kind that I designed on my dining room table with paper and pencil, so no CAD drawings are available at this time. I had never designed a transmission before this one. I used a book on tuning snowmobile clutches as my reference for my design. Unfortunately this book is out of print. If someone were interested in converting the paper drawings to CAD and making them available to the CD community, I might be able to fine a complete set and mail them to you. If there were more time, this could also make an interesting white paper.
Here’s a brief description of the function:
The drive side of the CVT responds to RPM and belt tension. One sheave is fixed to the shaft and the other is allowed to slide along the shaft but not slip. The faster the input shaft spins, the more the brass fly weights push the movable sheave toward the fixed sheave. The flyweight force is proportional to the square of the RPM and directly proportional to the mass of the weights. This device was designed to operate at about 1450 RPM. A snowmobile clutch operates at speeds up to 10,000 RPM. For this reason, the flyweights had to be rather large.
The driven side of the CVT responds to belt tension and torque on the output shaft. One sheave is fixed to the shaft and the other is free to slide and spin. The moving sheave is held against the fixed sheave by a spring that is inside of the aluminum cup with the cam surfaces. The movable sheave is kept from spinning on the shaft by three rollers that ride on the angled cam surfaces.
If the drive side is at full RPM and there is little or no load on the output shaft, the belt will be pulled down and the driven sheaves will be open. At this point, the CVT will be in high gear. If there is a load applied to the output shaft, the moving sheave will want to slip and will bear against the cam surfaces. The rollers will ride up the cam surfaces and push the sheaves back together. This will tighten the belt and pull the belt back down into the drive pulley and force the drive sheaves to open back up. This is known as “back shifting”
This CVT can function in either direction and does not have a neutral position. A snowmobile clutch only works in one direction and does not begin to bring the drive sheave together to contact the belt until the shaft is spinning about 2000 RPM.
The width of the V-belt and the angle of the side walls will determine the gear ratio change that is available. Because we wanted to use a small belt to keep parasitic losses to a minimum, we have a range of about 60% change from low to high gear.
We fitted this to one of our old robots and put the robot on our dynamometer to do some tuning of flyweight size and shape, cam profile, and driven clutch spring force. More development would would be required, but we are not pursuing it at this time.
Jay
Unread 08-12-2006, 23:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
My goodness. I'm glad you understand that. Nice work.
Unread 09-12-2006, 00:32
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
That sounds interesting. I'd like to do that, maybe during winter break in the last week of December. PM me if that would work.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 20-12-2006, 13:36
carbuff's Avatar
carbuff carbuff is offline
AKA: chad parsons
FRC #2228 (cougartech)
Team Role: Scout
carbuff has a spectacular aura aboutcarbuff has a spectacular aura aboutcarbuff has a spectacular aura about
nice we should all have a transmission like that
pic: Martians at WMR Beth Sweet Extra Discussion 3 04-05-2006 15:24
Thank you Martians Jack Jones Thanks and/or Congrats 10 16-12-2005 19:59
Cvt Jack Technical Discussion 4 05-10-2002 20:59
CVT Clark Gilbert Chit-Chat 10 11-05-2002 19:38
494 Goodrich Martians - Pictures cmartin03 Robot Showcase 4 18-02-2002 23:20
