Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Unread 20-12-2006, 17:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Steering wheel
Originally Posted by Qbranch View Post
I'm not exactly sure about using a steering wheel... the quick maneuvering changes one has to make when in a pushing match would be tough to pull off with the wheel. If youre using a wheel/caster or skid steer system, or any other system that has motor(s) on each side, I really would suggest just having a joystick for each.
The steering wheel would work if for some reason you chose to put turning wheels on the front of the robot, but like i say i'm just wondering if you can maneuver quickly enough with the wheel. I'm not questioning if you can do it, just the rate at which the driver can correct the path/power output of the robot might be a little sluggish. Anyhow, just my two bits.
-Q
If you think this is the case, clearly you've not seen the many extremely manueverable robots that use wheels. It's all about the implementation.
2001-2004: Team 100
2006-Present: Team 254
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Steering wheel problems jgannon Programming 4 16-01-2005 14:25
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
