Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 20-12-2006, 18:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Disk brakes
Originally Posted by Joel J. View Post
Last year IFI pointed out that the jumpers on the speed controllers could be wired to a digital IO port, allowing you to control in software the mode the speed controller was in. It made sense last year, as a team would have been able to enable brake mode, if the robot started to go in the direction opposite the one it was heading in as the match ended (WHILE DISABLED!). That is, you could have the robot coast up the ramp, and then not slide back down (if the dynamic brake was strong enough).
And you had enough traction.
The essential point that I was making is that the Victor brakes are almost always good for use in a drive-train in FIRST. I'm willing to bet that one of the robots involved in the pushing match (either yours or the robot trying to push you) will lose traction before the motors back-drive in brake mode. Especially considering a vast majority of pushing doesn't occur head on (a great deal of it is rotational in the world of FIRST, something that a braking mechanism that locks the wheels won't help with). If you want a system to prevent torqued out of position, it would have to be in contact with the playing field rather than the wheels.
Mechanical brakes (such as disk brakes) may be a valid solution for other aspects of the robot, such as arm and shoulder joints.
Victor Brakes xtolbert_gators Electrical 30 18-01-2007 12:57
Brakes pakrat Technical Discussion 34 06-05-2006 11:45
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
OCCRA Disk 2004 JoeFryman OCCRA 2 23-10-2004 17:07
Disk Shattered Joshua May Chit-Chat 15 23-09-2004 09:01
