Go to Post We are here to support each other. - Mike Martus [more]
Unread 20-12-2006, 10:28
Re: Disk brakes
Originally Posted by Viper37 View Post
The victors use power to slow down the robot...
That isn't how it works. In "brake" mode, a Victor speed controller isn't supplying any power to the motor. It's simply connecting both sides of the motor together, turning it into a dynamic brake.
Unread 20-12-2006, 10:47
REVving up for a new season
FRC #2848 (All-sparks)
Re: Disk brakes
another good source for brakes is here. The ones I would use are about halfway down the page. http://electricscooterparts.com/brakes.html
the 120mm is 4.72 in in diameter and with activation from a pneumatic cylinder they would be quite effective.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 20-12-2006, 13:09
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Re: Disk brakes
Hmm I wasnt aware of that, thanks for the info. However, a physical brake im sure can stop shaft movement much better than an electronic one.
Unread 20-12-2006, 13:22
Billfred's Avatar
Billfred Billfred is offline
Re: Disk brakes
Indeed it can--at the cost of extra weight and complexity. (Granted, they can be quite light if you design it right--look at 25's robot this year--but they still have mass.)
Unread 20-12-2006, 15:39
AKA: Matt Howard
Re: Disk brakes
Just another one of those times when you have to take into account what you want more.
Unread 20-12-2006, 16:13
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Disk brakes
Disk brakes sound really inefficient for a FIRST robot. Why not just take the (+) and (-) wires and have them touch (I am not giving away any concept designs, just an ideal concept). Take a motor and spin the shaft. Now connect the two wires together and try it again. It would be a lot harder, and even harder when you have that going through a gearbox.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 20-12-2006, 16:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Disk brakes
This is how the breaking feature on the Victors work.
--Madison--
...down at the Ozdust!
Unread 20-12-2006, 16:26
AKA: Matt Howard
Re: Disk brakes
However some people may want more braking power then that.
Another robot will certainly not have very much of a hard time pushing 2/4 motors on a transmission, especially if it already has the momentum going for it and it is using the same type of drivetrain.
Unread 20-12-2006, 17:02
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Re: Disk brakes
Woah! Is it like a programmable thing? Has his been around for a long time? I never looked into detail about the Victors.
Callsign: N6ARA
Unread 20-12-2006, 17:09
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Disk brakes
I'm looking at the DeWalt transmissions. Does the anti-backdrive pin on these work well/reliably? Sounds like a good way to hold up an arm.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 20-12-2006, 17:13
Madison's Avatar
FRC #0488 (Xbot)
Re: Disk brakes
There's a jumper on each Victor that allows you to decide if you want to set it to brake or coast. Brake is as described, while coast is what most folks use.
Teams have, in the past, created a servo-driven mechanism that allows them to switch between the coast and brake modes in the middle of a match.
Edit: Also, apparently you can program it to switch back and forth. You learn something new every day
--Madison--
Unread 20-12-2006, 17:15
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Disk brakes
The brake/coast jumper has always been on the Victors. Just move it from one position to the other. I think it usually ships in the coast position by default so you may have never noticed it. If you connect the jumper back to the robot controller digital I/O (switches) then you can program the Victor to either brake or coast at will.
Unread 20-12-2006, 17:18
Joel J's Avatar
do you..
Re: Disk brakes
Last year IFI pointed out that the jumpers on the speed controllers could be wired to a digital IO port, allowing you to control in software the mode the speed controller was in. It made sense last year, as a team would have been able to enable brake mode, if the robot started to go in the direction opposite the one it was heading in as the match ended (WHILE DISABLED!). That is, you could have the robot coast up the ramp, and then not slide back down (if the dynamic brake was strong enough).
Joel Johnson
Unread 20-12-2006, 18:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Disk brakes
And you had enough traction.
The essential point that I was making is that the Victor brakes are almost always good for use in a drive-train in FIRST. I'm willing to bet that one of the robots involved in the pushing match (either yours or the robot trying to push you) will lose traction before the motors back-drive in brake mode. Especially considering a vast majority of pushing doesn't occur head on (a great deal of it is rotational in the world of FIRST, something that a braking mechanism that locks the wheels won't help with). If you want a system to prevent torqued out of position, it would have to be in contact with the playing field rather than the wheels.
Mechanical brakes (such as disk brakes) may be a valid solution for other aspects of the robot, such as arm and shoulder joints.
Unread 20-12-2006, 18:16
Joel J's Avatar
do you..
Re: Disk brakes
My post was a follow up to M. Krass's.
As for what you are saying about brake mode: it is not that strong. It does provide some resistance to motion, but not alot. Brake mode seems good for allowing the robot to stop on a dime, and also for helping to keep an arm stationary. Break mode may not help much in a pushing match.
Joel Johnson
Victor Brakes xtolbert_gators Electrical 30 18-01-2007 12:57
Brakes pakrat Technical Discussion 34 06-05-2006 11:45
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
OCCRA Disk 2004 JoeFryman OCCRA 2 23-10-2004 17:07
Disk Shattered Joshua May Chit-Chat 15 23-09-2004 09:01
