Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 19-12-2006, 22:36
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
pic: 1881 new gearbox design
Unread 19-12-2006, 22:37
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: pic: 1881 new gearbox design
Is the gearbox a servo shift
Unread 20-12-2006, 08:48
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Nice compact design! Great to see a second year team looking to design gearboxes. Out of curiousity, how are you shifting? i.e. dog, mesh, ball, or an entirely new method?
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 20-12-2006, 09:06
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Dual speed, Check
Servo Shift, Check
Compact Design, Check
VERY Very good work guys, and Very good CAD model.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 20-12-2006, 09:09
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Have you considered how you will attach the CIM motors to the gearbox plates? You don't seem to be using both of the #10-32 UNF mounting holes on the front plate. Be aware that the other two holes on the front plate contain long bolts that hold the motor case together, and therefore may only be marginally suitable for mounting.
Also, while the lightening pockets are a good idea, have you considered that there's almost no clearance between opposite edges of the pocket in the lower corners. Unless you're casting it (not likely), or milling it with a tiny end mill (why?), you're going to have an issue with actually creating that detail. Also, you seem to have several non-circular curves in your lightening pockets. This implies you're going to make it on a CNC mill—is that your intention? If not, use straight-sided pockets.
Unread 20-12-2006, 12:29
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Counting the teeth. that gearbox has ratios of 2:1 and 3:1. with a CIM motor that gives you an approximate output speed of like 2500 rpm and 1500 rpm. that’s not getting much use for that gearbox's size and massively thick gears. and in an attempt to keep it small you removed the material of the plate that the motor needs to mount to. That is however some very impressive modeling with the pockets in the plates, the bearings and as far as I can tell from that render Nomenclatural correct Gears with some weight reduction. I remember myself modeling stuff like that back when just starting to use Cad and making it look super good. its just that i got so far into the aesthetic details of things that I skipped over doing the math in the bearing and meeting the requirements of my designs. Often a wheel speed to aim for is around 70RPM for a 6” wheel. In high gear, if you were to use that gearbox with a chain drive you would need a sprocket ratio of about 35:1 that may mean using a 12 tooth sprocket and a 420 tooth sprocket on your 6-inch wheel. seeing as how a 420T #35 sprocket would be around 50 inches in diameter. That won't work
Unread 20-12-2006, 21:23
GMAdan's Avatar
Thanks for the comments/suggestion. It's a ball lock shifter. I have relized my gearing mistakes, sorry i'm kinda new at this and made some math errors its back on the drawing board( well this case sketch plane) for me thanks.
Unread 21-12-2006, 01:59
AKA: Ty
No need to apologize, you didn't do anything wrong. your just learning. thats what the forums are for. please keep them coming. just Don't start taking bad blury pictures of things and call them teasers
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
pic: Our New T-Shirt Design!!! Nathan Pell Extra Discussion 19 10-01-2005 00:10
How to design a gearbox? Hinkel Y. Technical Discussion 14 07-04-2004 23:06
A question about gearbox design . . Frank(Aflak) Technical Discussion 14 02-10-2003 14:57
