Go to Post I found another student once at a Cross Country meet because she was wearing a team shirt. I must say, I was surprised. I should start wearing my team shirt around more often. - TheBoulderite [more]
Unread 20-12-2006, 22:18
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Blinking Red Light
Hey,
Code uploads, and works without the camera code..... on the other hand... when the camera code is added.... it'll upload and the program state will blink as well on the I/O...it will flash red on code error.... any hints on why this is happening??
Ps... controller is either 2005, 2006.... doesnt say on controller
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 20-12-2006, 22:55
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Blinking Red Light
you need to find out which controller it is, the camera code uses some libraries that need to be correct for the PIC inside, try reading the txt file included about using a previous years RC and see if that works.
KK4KQO
http://voltair.us
Unread 20-12-2006, 22:58
AKA: !!Mitch!!
FRC #1392
Yes i think that will work cuz i just uploaded the old 2005 code ... and it works with the camera and everything.... thanxs for the help
Unread 21-12-2006, 08:57
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
When you run IFI Loader and do a Controller Verify it should tell you what controller it is.
Unread 21-12-2006, 17:17
AKA: !!Mitch!!
FRC #1392
Ye i do that but it doesnt say wat it is..... it just says version and FRC
also i keep getting this error'
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - processor types do not agree across all input files.
Errors : 1
BUILD FAILED: Thu Dec 21 17:14:28 2006
Unread 21-12-2006, 18:11
Cuog's Avatar
AKA: Alex
FRC #0422
Did you follow all the instructions on using last years RC as I'm pretty sure that you have an 05?
KK4KQO
http://voltair.us
Unread 21-12-2006, 22:16
AKA: !!Mitch!!
FRC #1392
Mostly likely that i do. do u have the txt file that explains how to change the linker files or w.e? plz and thxs
Unread 21-12-2006, 22:57
Cuog's Avatar
AKA: Alex
FRC #0422
Originally Posted by previously mentioned txt file
To compile this project to work with your 2005 FRC (18F8520) system do the following:
1. Select the correct device from the MPLAB IDE.
Configure->Select Device->PIC18F8520
2. Replace the library file with the appropriate one.
Remove the FRC_Library.lib file and replace it with FRC_Library_8520.lib
or
Remove the FRC_alltimers.lib file and replace it with FRC_alltimers_8520.lib
3. Remove the 18f8722.lkr file and replace it with the 18f8520.lkr file
4. Rebuild your project and download the HEX file to your controller.
There you go
KK4KQO
http://voltair.us
Unread 21-12-2006, 23:13
AKA: !!Mitch!!
FRC #1392
There you go
awesome thxs alot
Program light is blinking red elsacr FIRST Tech Challenge 1 27-02-2006 10:23
OI Aux Fault light red Vashts6583 Control System 1 25-01-2006 23:10
Blinking Program light on RC jgannon Programming 2 16-02-2005 22:45
program light blinks red and green JBabbie Programming 3 02-03-2004 09:19
Lost Red Light Globe team 27 Bduggan04 Off-Season Events 0 18-10-2003 19:05
