Is there a schematic for the VEX Controller?
It would be invaluable in interfacing to a wide range of peripherals. I've been in the embedded controller area for years and think it would be fun to see what this beast can do if we take the restraints off! |
Re: Schematic
I think due to the fact that they dont want people competing with modified controllers they have not release a schematic. However they arent that expensive if you wnat to buy one, open it up and play around with it.
Re: Schematic
That will happen very soon
Re: Schematic
there's not much to it, a multi layer board, two surface mount PICs (18F8520) and some support circuitry....looks like it's pretty much a straight shot from the PIC to the io ports....
Re: Schematic
I'm wondering if IFI has built any security into their controllers. I'm pretty sure the two processors are connected via SPI, so a re flash of both will give you two processors to play around with. It may be hard to check that without bricking the controller though.
Re: Schematic
Do PICs support this? If not, or if its not enabled by chance, you can try to do a read-back of both chips Flash to get an idea of what they're doing. Of course IFI might show up on your doorstep with one of those MIB flashy-things... |
#7
Re: Schematic
Re: Schematic
Re: Schematic
Re: Schematic
not only are they $150, but they're vaporware....out of stock....
yeah, I have a picture....only 4 screws take off the cover, and there's nothing on the bottom of the board but a ground plane and a bunch of thru-holes. |
| I need the 2006 Wiring Schematic Diagram | SkD_nub | Electrical | 2 | 06-02-2006 14:46 |
| Analog Joystick Schematic | DonRotolo | Control System | 4 | 13-03-2005 22:06 |
| Electrical Schematic/ Wiring diagram | sanddrag | Electrical | 9 | 11-01-2005 12:51 |
| Robot Electrical Schematic | CHSguard72 | Electrical | 5 | 03-03-2003 21:30 |
| drill gearbox schematic? | Jeff Sharpe | Technical Discussion | 3 | 21-01-2003 00:18 |
