Re: motor stall current vs Victor ratings
R54 refers to the battery and the 120 amp breaker, directly,
in the singular. That, in combination with the diagrams and the fact that the breaker clearly protects the 6 gauge wire, battery connector, and battery from overcurrent, makes the intent of R54 clear. Seeing this as a loophole is quite a stretch. I don't think that you would get this one past any technical inspector. Eugene Quote:
-- Tristan is an experienced FRC robot inspector.But I agree with Eugene about the intent of the rule. |
The EX18/ES18 battery specification lists a maximum rating of 230A for 5 seconds. Various estimates of a 120A load based upon the the battery specification chart and different derating values yields between 20-40 seconds of rated battery life. Real life experience may differ, but the these are the rated values from the specification.
So on the practical side, pushing the battery beyond 120A for all but short brief periods will mean the 'bot will die before the round is over. Running two 120A main breakers would seem to indicate the design only wants the robot to run a few seconds before completely draining the battery AND it would allow the battery to be run outside of its specifications. Running the battery anywhere up around the maximum rated value of 200A+ for any time at all is flirting will damaging the battery at least or causing some safety issue like melting or worse. Also, the number of discharge/charge cycles the battery can go through is highly dependent upon the rate and depth of discharge. Draining capacity at high loads can severely shorten the lifetime of the battery. Some data on AGM/GEL cells indicates as few as 10s of cycles under these extreme circumstances. So even if you wanted to run multiple 120A breakers, there is no practical reason to do so -- the battery would at best drain very quickly and not last through the competition. All such a design would be doing is causing a potential risk to the robot as well as others. Of course there have been rumors of changing the battery for this upcoming season, so there may be a whole different set of issues in two weeks to discover. On the practical side, the motors when geared down seldom fully stall but instead start spinning the wheels even with grippy treads. Bud Last edited by dcbrown : 23-12-2006 at 14:13. |
Thank you all for your replies. This is certainly a credit to the FIRST gracious professionalism creed.
Still one curiousity comparing my BBIQ experience with FIRST robots. Most teams at BBIQ used 24v systems for drive, motors from 1-3 hp PER SIDE (or 2-6 hp total in the differential drive), and batteries with 5-6 AH ratings. The playing surface was sandtextured paint on steel, which ended up fairly slick by the third day of competition. If two bots pushed against each other, one would move or the wheels would spin. This lack of traction compared to rubber on carpet as with FIRST would protect BBIQ bots from burning up Victors or motors. But I still saw several burned motors or Victors (pink/grey smoke) each year. The FIRST motors are approx 1/2 hp for the largest ones. The battery has higher AH rating letting it keep up with whatever the motor draws. The playing surface with rubber tires is less forgiving (no slipping to protect the Victors and motors). To my thinking, this means robots pushing against each other won't be able to move each other. Thus more likely to stall the motor. Even geared down, if you push against the side of the opponent, you won't be able to move it, and that is still a stalled motor. The 4 largest motors draw 133, 96 or 63 amps at stall. That exceeds the 40 amp rating of the Victor 884. The Victor 884 doesn't list a higher current for any short time (as the Victor 885 does). So do you suggest a single Victor 884 for one of these large motors, or two in parallel for each motor, each with an independent 40A circuit breaker? Thanks again! |
What I usually see the robot designers do is to select a traction material for their wheels, then calculate the maximum torque they can get with those wheels, given the robots weight, as a first step. So lets say there is a 6 inch tire, a 150lb robot, and the coefficient of friction between the wheel and the floor is 1.3 (IFI roughtop tread). The gearbox designers would calculate the max torque at the wheel to be: 150*1.3*3(tire radius) = 585 in-lbs. Convert that to the oz-in units that's given on the CIM motor chart, and you get 9360 oz-in's at the wheel before it starts slipping. I've typically seen FIRST drivetrains use the 4 identical CIM motors, two per side, meaning that the load would be evenly shared across these motors. So each motor needs to provide 9360/4 oz-in's of torque, or 2340 oz-in. The designer would then determine the amount of torque they would get when pulling 40 amps from the CIM motor, as opposed to the 133 amps at stall (let's say its 105.43 oz-in's, as opposed to the stall torque of 343.4 oz-in). Divide the torque needed from the individual motor by the max load you want it to see, and you get the reduction needed between the motor and the wheel. In this case 2340/105.43 gives a reduction of 22.1948 minimum. When you reduce the free speed of the CIM motor (5310 RPM) 22:1, you get a final RPM of 239.245, which translates to a ground speed of 6.2634 fps. I didn't factor in losses (4.5253 fps, with losses, on most one speeds.. 4.1fps on a typical 2 speed). At this reduction, the idea is that the wheels would start spinning before the motors begin to pull more than 40 amps, preventing stall. I guess the idea is similar to having a low traction surface to play on. If the final speed you get after doing these calculations is too low, then you just lower the "grippiness" of the wheels you are using. If you want to be a strong pusher, you can only lower the grippiness so much before you start losing traction advantage. You'll start getting into the whole tradeoff between speed/torque/current pull that I just can't bother with; I'll stick to programming.
This was a bit rushed. If you want a detailed description of this idea, you can search around the forums for topics on drivetrain design, or gearbox design, or something.. Last edited by Joel J : 23-12-2006 at 16:50. |
At River Rage, drivers of our team bot which used two CIM motors, 6 wheel drive with 2" wide IFI roughtop tires side pushed all the robots it came up against to prevent shooters from scoring. Motors never stalled, breakers never popped. The robot used the KOPS transmissions and weren't geared down very far from there - that is top speed was still acceptable.
Bud Last edited by dcbrown : 23-12-2006 at 18:10. |
#7
Unless the rules change this coming season, relative to last year, I suggest a single 40 amp breaker, feeding a single Victor 884, connected to a single CIM motor.
Yes, the Victor 884 is rated at 40 amps continuous, and the breaker is rated at 40 amps, but both of these parts will sustain higher currents for short time periods. Eugene Quote:
#8
1) the drivers are trained not to keep pushing if we're not moving--that would release magic smoke for sure if the wheels weren't slipping which brings me to: 2) our wheels start to slip when pushing against something relatively static at somewhere around half power, so our motors don't stall unless the driver stalls them on purpose (holds them at quarter power for a long time). We still have a strong pushing force; ask anyone who has played against us. Quote:
JBot |
#9
Refer to "FIRST Guidelines, Tips and Good Practices"
and the "Robot Power Distribution Diagram." These documents are updated each season. R80 refers to the robot power distribution diagram. I see our robot is traveling in circles... Eugene Quote:
#10
Now i have to ask:
How long before we melt the anderson power-pole connectors? them seem to be the weakest factor. Just a thought. |
#11
Keep in mind that while a robot is in a pushing match they are not scoring points. Scoring point wins matches. Yes, defense comes into play, but a well coordinated offense can neutralize a defense with picks and such. First play is different than battle bots and the rules more limiting.
#12
while the specifics depend on the game and startegy, an effective and powerful drive train can be a potent offensive weapon. |
#13
DA,
Maximum rated current for a Victor was published a few years ago but can be derived from the current specifications for the MOSFETs used. Keep in mind that each FET is in parallel with two others for current sharing but that there is derating due to lack of heatsink. The FETs have a very low "on" resistance and so very little power is dissipated within the device which keeps internal heating to a minimum. However, there are other factors...usually at maximum current, a) the speed controller is no longer using a PWM output, it is at full "on", b) the motor is at or near stall, c) the motor may be back driven by a pushing robot, d) bad electrical connections at the Victor will raise it's temperature due to heating of the contact area, e) the fans become inefficient due to the lower battery voltage. Keep in mind that about 90% of all speed controller failures are due to foreign and conductive material inside the controller. The remaining failures are a result of incorrect wiring, over heating, repeated high current due to stalled motors or rapid direction changes or defective mechanical systems. As pointed out, many teams design for at least 6 ft/sec but speeds from 8-12 ft/sec are acceptable. Higher speed designs will result in mechanical systems that will easily stall and draw excessive currents when starting or accelerating. |
#14
| Victor 884 Fan Current | Fishdude404 | Electrical | 2 | 29-01-2006 20:06 |
| Victor Input / Motor Control | Jack | Electrical | 5 | 01-12-2004 02:23 |
| Motor Question- Victor/Spike? | 1166 | Motors | 10 | 16-02-2004 16:57 |
| So you want to stall a Globe Motor... | archiver | 2000 | 1 | 24-06-2002 00:09 |
| DC Motor current to an Analog Input | junkyarddawg | Motors | 43 | 04-04-2002 15:53 |
