Go to Post Part of the magic of FIRST is the interaction between different teams- and that becomes clear as day as the clock starts ticking. - mhayon [more]
Unread 22-12-2006, 21:53
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Anyone used the new CMUCam2plus?
So, I was just surfing the parts stores online and came across the "new" CMUCam2+. It's all integrated on one board. looks pretty nice.
Since IFI is "sold out" of last year's model I'm thinking that maybe the new kit will contain a "plus".
Anyone used one of these?.. is the code "compatible" with the CMUCam2?
Thanks.
Phil Malone
http://www.GEARSinc.org
Unread 22-12-2006, 22:25
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Re: Anyone used the new CMUCam2plus?
mind if i have the link.. i cant seem to find the cam
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 22-12-2006, 22:33
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Try here. Wonder if it's in 2007's KOP.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 22-12-2006, 22:44
AKA: !!Mitch!!
FRC #1392
Looks very kool.. but i highly dought this would be the camera Unless!! it came with a ttl adapter for the serial cable. who knows, maybe im wrong... either or! its looks sick! i'd love to use it 1 day if i could get my hands on it.....also if this is the new cam we are getting ... maybe it'll have extra features... like being able to view an object in the dark or something
Unread 23-12-2006, 10:17
PhilBot's Avatar
AKA: Phil Malone
I personally would like to see the Plus version in the 07 Kit, because it overcomes two big problems we had with the CMUCam2:
1) We had one unit where the power switch went bad. The new unit looks like it uses a larger more robust switch (that is acessible from the outer edge)
2) The camera board had a connector on one edge, but no way to firmly mount the board to the carrier. So if the bot got bumped, the camera could move and wreck your shooter allignment. We resorted to a spacer and hot glue. It worked, but it wasn't any fun when we had to replace the board with the bad switch.
The 06 Kit came with a RS232 adapter for the RC, I guess we'd also need one to connect to a PC for testing.
Phil Malone
Unread 23-12-2006, 11:21
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Ah yes indeed. We put a piece of plastic dowel between the camera board and the main board, then screwed the camera board into the dowel. There are little tiny holes at the edges of the camera board that we used, but it was rather difficult finding screws that small.
With a redesigned pan-tilt housing from IFI, the CMUCam2+ looks like a much better alternative.
Unread 23-12-2006, 12:08
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I like that its all in one unit. This will keep the camera from comming loose on the board after the robot takes a few hits.
Unread 24-12-2006, 19:32
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Off course, if IFI did use that, it would kill any possibility of simultaneous tracking of multiple colors. You can do that on the CMUcam2, using slave mode. But since that requires hooking the camera board to several processing boards, it discludes the CMUcam2+ from such an arrangement.
Doubtless, it will be interesting.
Unread 25-12-2006, 00:01
PhilBot's Avatar
AKA: Phil Malone
OK, that's seriously cool. I had no idea you could do that.
Is the serial comms to each processor board shared (multi-drop), or do you need to use dedicated serial channels?
Phil Malone
Google Adsense - Anyone used it? sanddrag IT / Communications 6 06-02-2006 09:10
How to Make MS joystick work/has anyone used it in past? andhesayz Control System 25 17-01-2005 10:34
Anyone ever used Rush Gears as a Source? Matt Reiland Technical Discussion 6 21-01-2003 03:26
So does anyone know what the name of the new field archiver 2001 4 24-06-2002 03:01
