Go to Post ..attitude and willingness to work as a team...are the qualities that can make or break a team. - Monochron [more]
Unread 24-12-2006, 00:03
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
Looking for 2005 or 2006 Robot Controller
Hi everyone,
We're looking for an extra robot controller so we can make a little prototype robot with the new freshmen. We had it all built, and were disappointed when we realized the 2004 controller uses the edu code... correct?
I guess it's already getting to pinch-time, though. Excited about the kickoff? I am!
If you have an extra robot controller you would be willing to sell, please let me know!
~Dave
Team 706
Unread 24-12-2006, 00:08
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Looking for 2005 or 2006 Robot Controller
edu code?
the 04 controller is in C just like the 05 and 06
Unread 24-12-2006, 01:29
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
There are technically two 2004 controllers, either of which could be useful. The "mini" controller does in fact use EDU code, but that doesn't preclude it from being useful.
If you're using the mini-RC, you can use it to teach freshman autonomous mode, unless you want to invest in the R/C control system you'd need to make it tele-op capable. Even standalone it's invaluably useful for teaching programming, and testing out little designs.
If it's the regular RC, you're golden, just update to master v12 and start working with the full size 2005 default code (2006 would need some conversion, it's well documented you can try that as well if you'd like. Might be a good freshman project.)
Matt Krass
Unread 24-12-2006, 08:32
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I dont know how easy it will be for you to find an 04,05,or 06 controller. You best bet is to buy the mini-RC. However there might be a team hear willing to give up an old controller, but I doubt it.
Unread 24-12-2006, 13:00
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
When do you need it by? We're on winter break right now, but I will ask my team.
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 24-12-2006, 23:18
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
The mini RC still runs on C and the code is virtually identical to
that of the regular RC. you can still layout all your autonomous
code the same. There are only slight differences that you probably
wont even notice
Unread 25-12-2006, 10:13
How do I update that? Seems like that would be the best option right now?
Unread 26-12-2006, 00:15
Matt Krass's Avatar
AKA: Dark Ages
Get the updated code from here: http://www.ifirobotics.com/rc.shtml#Programming
Download the 2006 default code, included is a ZIP file with the default code for the new controller, instructions for converting it to run on the 2004/2005 controllers, which are good to run through as a basic project as well.
To do the master update, select the FRC_MASTER_V12.BIN file in IFI Loader, make sure the OI/RC are tethered and both connected to stable power (Wall warts and such). IFI Loader will automatically switch to Master update mode and warn you not to disconnect anything and such, it makes it seem kind of scary, but as long as you don't have a complete power failure during the update, or trip over anything and knock it out, you're clear.
I'd recommend updating to Master Code 12, then converting the Default Code to run on previous controllers (there's a .txt file in the ZIP detailing that process as well) and getting that to run, then saving the whole directory. Good way to get started.
Let me know if you need any other help.
Matt Krass
Unread 27-12-2006, 01:21
Thanks a lot, I got it working.
Wanted: 2006 Robot Controller BradyP4 Control System 3 06-08-2006 21:13
Wanted: 2005 Robot Controller BSMFIRST Control System 0 01-03-2006 11:27
robot controller 2005 2004 CharlieWilken Programming 5 20-02-2006 09:43
Team 751 looking to buy a robot-side controller davidmandle Control System 6 12-01-2006 12:00
Looking for Volunteers for the 2006 season! Ferazel2001 General Forum 15 03-01-2006 01:30
