Go to Post Ive always wondered about this - if DK has an alter ego, like Clark Kent and Superman - KenWittlief [more]
Unread 24-12-2006, 18:32
nonother's Avatar
nonother nonother is offline
Founder
FTC #3053 (Occam's Engineers)
nonother will become famous soon enoughnonother will become famous soon enough
Re: Gears or chain and sprockets?
Our team's experience with using chain and sprocket for drive trains is that it is disasterous. The amount of tension present causes one of two problems. The first is the chains simply snap. This could probably be remedied with doubling up chains. The second scenario that is far more troubling is the chains loosen eventually and so the amount of tension is reduced. When the gears spin the amount of tension on each side of the gears is not equal and so the difference in tension then causes the chain to snap. This seems to happen even when doubling up. Bottom line - if the situation requires high torque or has a lot of stress on it avoid chain and sprockets.
On another note - gears are hardly impervious. I've seen them snap, which just confirms my belief they should have made them out of metal. So if there is going to be a lot of stress on the setup, double up all of the gears.
Unread 25-12-2006, 00:55
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
thanks,
after much consideration, our team decided to gear the drive train and use chains/gears for the arm lift
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 25-12-2006, 01:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The Vex chain is plenty strong enough, as long as it is tensioned properly. If your chain is too tight or too loose, it will snap much easier.
FVC 228 (formerly FVC 59) last year used Vex chain for driving their robot, and they did not have any problems with it breaking. Over the course of two competitions (in which they placed 2nd in both) they only broke the chain once, and that was because another robot rode up onto the frame of our team's robot, and the wheels of the other robot became entangled with the chain on ours.
Here's a few pictures of their robot: (sorry for their large size)
Art Dutra IV
世上无难事,只怕有心人.
Sprockets and Chain MechaJag Kit & Additional Hardware 4 08-02-2004 22:45
Gears and Sprockets Pat Roche Inventor 3 13-12-2003 18:38
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Nylon Roller Chain Sprockets Jim Smith Technical Discussion 6 20-01-2003 20:01
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
