Go to Post Don't give FIRST ideas...we like our 45 day build season. They can make it shorter. Never underestimate the power of the GDC. - Littleboy [more]
Unread 24-12-2006, 16:32
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Programming for CMUCam
Hey quick question..
To stop the Servo_Track(); from tracking.. could i just say Tracking_Initialized = 0; to stop it?
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 24-12-2006, 16:56
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Programming for CMUCam
You can just not call the function..
if (track_enabled == 1)
Servo_Track();
Unread 24-12-2006, 17:37
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Remember that the robot runs on a continuos loop. So instead of stopping it, you just need to not call in on they next loop if you dont want it to be running.
Unread 24-12-2006, 18:47
AKA: !!Mitch!!
FRC #1392
How would i do that? ..
Unread 24-12-2006, 18:51
Team 2021 Captain
AKA: Chris Davidson
Dont call Servo_trace in you user_routine when you dont want it to run. Say you only want it to run when switch_1 is on then it would look like this
PHP Code:
if (switch_1 == 1)
Servo_Track();
Unread 24-12-2006, 19:01
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
In user_routines.c in Kevin Watson's "bells and whistles" version of his camera code (which you are probably using if you are calling Servo_Track()) there is this code:
	// This function reads data placed in the T_Packet_Data
	// structure by the Camera_Handler() function and if new
	// tracking data is available, attempts to keep the center
	// of the tracked object in the center of the camera's
	// image using two servos that drive a pan/tilt platform.
	// If the camera doesn't have the object within it's field
	// of view, this function will execute a search algorithm
	// in an attempt to find the object.
	if(tracking_menu_active == 0)
		Servo_Track();
You are looking at the last bit there. That code checks if the code in terminal.c (I think) has set the tracking_menu_active variable to 0; if it has, it calls Servo_Track(). What you want to do is modify the line two lines above Servo_Track(); to read something like:
if((tracking_menu_active == 0)&&(whatever condition you want here))
where "whatever condition you want here" is replaced by what you want your code to check to see if it should call Servo_Track(). You could have a variable, for instance, called jbotRulesTheWorld (hey, I just had to add that ) and you want your code to call Servo_Track() if jbotRulesTheWorld equals 1. You would write:
if((tracking_menu_active == 0)&&(jbotRulesTheWorld == 1))
in place of the original
Good luck, and if you need more help don't hesitate to post back here.
JBot (rules the world... )
EDIT: Oh, well Chris31 beat me to it. I'll still leave this post here for clarity.
Aren't signatures a bit outdated?
Unread 25-12-2006, 00:23
AKA: !!Mitch!!
FRC #1392
found an easier way .... i'll just declare Camera_Idle(); ... that'll stop everything that its trying to track.. but thxs alot for ur help
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
CMUcam for Dummies? nosaj4268 Programming 2 14-01-2006 23:55
Program for CMUcam valahan Programming 1 10-01-2006 18:03
CMUcam autonomous programming kshot Programming 1 17-01-2005 19:18
