Go to Post A HUMAN PLAYER is not a ROBOT. - cgmv123 [more]
Unread 23-12-2006, 22:14
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Gears or chain and sprockets?
What are the advantages/disadvantages of gears or chain and sprockets. I cant really tell any difference between them except that chains break quite easily.
So, in terms of driving or lifting a heavy manipulator, what are the advantages and disadvantages of both, and which one is better from your investigation?
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 23-12-2006, 23:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gears or chain and sprockets?
Well, it might depend on where you want to put your motor. A chain can be many different lengths, whereas gears must go in certain places. Additionally, gears must ride on shafts.
Unread 24-12-2006, 11:23
DonRotolo's Avatar
Back to humble
FRC #0832
Sanddrag covers the basic issues well.
On the other hand, you can use multiple chains to increase strength.
Don
Unread 24-12-2006, 11:51
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Using sprockets and chain gives you a wide range of ratios you can use. Also, it is fairly easy to swap sprockets to change the ratio during a competition, but gears require quite a bit of redesigning of the robot. The downside with chain is of course its weakness, but as mentioned above you can make it stronger by using multiple chains.
Unread 24-12-2006, 16:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
There are more options in terms of ratios for sprockets than gears, but the chain is considerably weaker than the teeth on gears (although they are far from impervious as well). You can double-up on both chains or gears if they stress is too high though, and some have used tank treads for transmission of power over long distances (such as FVC 40 and 1281). Gears tend to take a bit more meticulous designing to get them to fit properly than chains do (especially in FVC), and gears cannot have anything between the origin of power and the output of power, aside of the gears (while a chain can go around an object or spacer).
Unread 24-12-2006, 16:20
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
From my many experimentations I have found that gears are more reliable in high tourqe situations and some drivetrains. Whereas chain is good in tight areas so you can mount the motor else where and transmit power over a distance. Also I like to use 6 wheel drives alot and usually I have ATLEAST one wheel powered directly from the motor(through gears or direct drive) and then drive the remaining wheels with chain from that shaft and the hope is that if the chain breaks then the robot can still move a little. When you need to use chain in a high stress application it is better to use 2+ chains.
-Dustin Benedict
Unread 24-12-2006, 18:32
nonother's Avatar
nonother nonother is offline
Founder
FTC #3053 (Occam's Engineers)
nonother will become famous soon enoughnonother will become famous soon enough
Our team's experience with using chain and sprocket for drive trains is that it is disasterous. The amount of tension present causes one of two problems. The first is the chains simply snap. This could probably be remedied with doubling up chains. The second scenario that is far more troubling is the chains loosen eventually and so the amount of tension is reduced. When the gears spin the amount of tension on each side of the gears is not equal and so the difference in tension then causes the chain to snap. This seems to happen even when doubling up. Bottom line - if the situation requires high torque or has a lot of stress on it avoid chain and sprockets.
On another note - gears are hardly impervious. I've seen them snap, which just confirms my belief they should have made them out of metal. So if there is going to be a lot of stress on the setup, double up all of the gears.
Unread 25-12-2006, 00:55
fredliu168's Avatar
thanks,
after much consideration, our team decided to gear the drive train and use chains/gears for the arm lift
In 2006
In 2007
Events:
Unread 25-12-2006, 01:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The Vex chain is plenty strong enough, as long as it is tensioned properly. If your chain is too tight or too loose, it will snap much easier.
FVC 228 (formerly FVC 59) last year used Vex chain for driving their robot, and they did not have any problems with it breaking. Over the course of two competitions (in which they placed 2nd in both) they only broke the chain once, and that was because another robot rode up onto the frame of our team's robot, and the wheels of the other robot became entangled with the chain on ours.
Here's a few pictures of their robot: (sorry for their large size)
Art Dutra IV
世上无难事,只怕有心人.
Sprockets and Chain MechaJag Kit & Additional Hardware 4 08-02-2004 22:45
Gears and Sprockets Pat Roche Inventor 3 13-12-2003 18:38
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Nylon Roller Chain Sprockets Jim Smith Technical Discussion 6 20-01-2003 20:01
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
