Re: flexible materials
So you don't want to just create the bend? I don't think Inventor has flexible materials available. I know Inventor 10 has a plywood color for parts, and you could loft or extrude the part you want.
Lofting surfaces would probably be the best way to go. |
Lofting is the best way to go. Either that, or just design it into the assembly from a side view on the bend, which may end up more exact. Sheet metal would work, but it'd be easier once Inv. 12 hits, where they'll fix sheet metal to make ti work better.
I don't think you can do it in Inventor but you can do it in SolidWorks and now that SoldiWorks is availible to teams...
| Flexible shafts working with CIMs | mechanicalbrain | Motors | 8 | 07-07-2006 23:38 |
| Flexible, Bendable Rod | blue_crew | Technical Discussion | 7 | 30-03-2006 19:18 |
| Super flexible Wire | want2modmygt | Electrical | 10 | 18-01-2006 18:39 |
| Flexible cable management | Doug G | Electrical | 12 | 10-11-2005 14:04 |
| Where to get lightweight flexible coupling? | sanddrag | Technical Discussion | 3 | 20-01-2005 01:22 |
