Go to Post "This is the year that everyone on CD is going to learn to spell." "This is the year that everyone on CD will make a serious effort to write grammatically correct sentences." "This is the year that everyone on CD will think BEFORE they post." ... nah. - dlavery [more]
Unread 20-12-2006, 22:53
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: #25 Chain Information
#25 chain is nice and light, it was still strong enough for us in 05. The problem is that getting more in a hurry is a problem since it isn't used as much in FIRST. Also its smaller and you have to use a different chain breaker and the master links and half links are a royal pain in the...
Other than that if you don't mind the extra effort of using the chain and the lower number of available sprockets you will be happy with its weight savings.
KK4KQO
http://voltair.us
Unread 21-12-2006, 00:00
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
I want to thank everyone for their input. We will be making a prototype with 25 chain and seeing how it goes. We are going to most likely use wedge top as our material of contact with the carpet (or w/e it is) and according to what you guys are saying the rubber should spin before the chain breaks. Also our gearboxes are not "over designed" so we rather lose chain than damage the gearbox by having the strong chain (thanks for pointing that out)
I am glad to hear so many good comments about 25 chain because I wasn't sure, but it definitely sounds like worth a try.
It will be great if people who have more information on this chain can keep posting it as it will be helpful to my team and I am sure many others.
David
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 25-12-2006, 13:30
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Theres another thread with lots of tensioning ideas at http://www.chiefdelphi.com/forums/sh...474#post249653
Zan Hecht
Unread 25-12-2006, 22:01
Andrew Blair's Avatar
FRC #0306 (CRT)
I'd like to stress that, as Sanddrag and Travis pointed out, proper alignment and tensioning is crucial. We've used #25 practically forever, and had great success- and failure. #25 is almost entirely suitable as far as FIRST goes in terms of actual chain tension loading. What the motors put out, stopping and starting forces- the chain can handle the tension forces well.
However, #25 will quickly inform you if there is *any* misalignment, angular or lateral, mis-tensioning, or other problems. Last year, even with properly tensioned, aligned, and lightly loaded chain, if we ran over a ball, we crossed our fingers!
Regionals can be a humbling and frustrating experience should you screw up- mechanical reliability is paramount, and badly implemented #25 *will* cause problems there. We broke ~6 chains at Pittsburgh last year, and paid the price. Limping robots are bad robots. However, we tensioned and protected the chains better, and had a great success rate.
As Travis said, you must evaluate each case individually and weigh the consequences. You save huge amounts of weight using #25, but it's very important to design the system well. It will not hold up to running barriers over, or rubbing against a bent frame, or dealing with the mis-alignment caused by that bent frame. But I don't want to get too down on #25; we love it! It saves so much weight, and when properly implemented, won't give you any headaches. Just be careful!
-Sir Francis Bacon
-Albert Einstein
Unread 26-12-2006, 00:39
JoshuaFreier JoshuaFreier is offline
FRC #0467 (Duct Tape Bandits)
JoshuaFreier will become famous soon enough
Send a message via Yahoo to JoshuaFreier
One additional bit of information our team has found over the past six years of working with #25 chain is you must do a better job aligning the sprockets then you do with #35. #25 chain is much less forgiving in this regard.
Have Fun,
Joshua
Hope is a good thing, maybe the best of things...
...and a good thing never dies.
Unread 10-01-2007, 22:59
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
We have used #25 chain for years for our 6WD drive train with good reliability. The chain itself is very strong, like 700+ pound breaking strength, and is, of course, much lighter than #35 chain. Also, it allows us to get more reduction between the transmission output and the wheels than is possible with larger chain.
Good alignment is much more important than with #35 chain, and you need to have adequate wrap on smallish sprockets. We use a single chain around a transmission output sprocket, a tensioner, and the three wheel sprockets. Some of our machines have had only about 90 degrees of wrap on a 19 or 20 tooth transmission output sprocket, and the chain needs to be pretty tight or it can slip, not a good thing. The bottom line is that #25 chain will work for most applications on our machines, but everything needs to be more precise than with larger chain, including sprocket alignment, lack of wobble, and lack of runout of the sprockets.
Team 1062, The Storm, 2003
Information Technology or Information Systems ? pheNIX637 Career 1 27-10-2005 18:43
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
chain Lake Orion OCCRA 1 30-09-2001 13:20
