Go to Post Recently my wife and I met some mentors from Michigan with their wives at Disney World. It seems that I'm not the only mentor who needs to bribe their wives with vacations before they sign up to mentor FRC for another year... - Mark Holschuh [more]
Unread 25-12-2006, 01:20
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
pic: team 1881's trans V2
Unread 25-12-2006, 01:25
GMAdan's Avatar
Re: pic: team 1881's trans V2
This is the second verison of the 2 speed ball-lock transmission that team 1881 is designing. some major changes have been made to the gearing. The new gear set is:
12t-60t main hub driving
30t-50t
40t-40t
Suggestions and commments would be helpful, thank you
Unread 25-12-2006, 15:42
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Depending on the size of the wheels you are planning on using, you may want to reduce the ratio further, but that can also be done after the gearbox (typically via chain and sprocket). But for a 5-6" that is probably around where you want.
Unread 26-12-2006, 00:14
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Excellent work. Your well on your way to perfection. most of what's left has to do with the tools ability to create the shapes you want. liek square corners, matching tangents and milling pockets. and most importantly Placing your holes where they need to be.
Unread 26-12-2006, 00:20
REVving up for a new season
FRC #2848 (All-sparks)
I curious why you decided to go from low to high to mid, instead of going in order? Do you have some strategy behind this...if so enlighten us.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 26-12-2006, 12:44
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Its only a two speed transmission; low-high. The large gear furthest from the front seen on the bottom (input) shaft is the mate for the two small gears on the CIM motors. It has no paired gear up on the top (output) shaft. It just provides CIM power to the constantly locked on bottom gears so they may spin the free-wheeling-until-locked gears up top.
Mechanical Engineer
Digital Lumens
NU ME: 2011
2009 Trans-Am? Matt Attallah Chit-Chat 12 01-04-2006 01:08
Last years versus this years trans. ratios de_ Motors 4 12-01-2006 13:56
pic: Team 334 Team Members after the CeBit Convention CD47-Bot Extra Discussion 2 29-05-2004 14:14
Ohh Well another trans down the tube Matt Reiland Technical Discussion 20 15-01-2004 20:24
Has any one stuck a drill motor in the FP trans? Lotownvw Motors 15 21-04-2003 23:57
