Go to Post You can make unfounded guesses, but chances are you'll come off looking like a moron. Let's try and avoid that. - Karthik [more]
Unread 25-12-2006, 15:51
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
flexible materials
Is there a way to work with flexible materials with inventor 11?
I want to draw a plywood boat and it would be really cool if i could flex the panels into place instead of making everything prism-like.
Unread 25-12-2006, 21:19
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: flexible materials
So you don't want to just create the bend? I don't think Inventor has flexible materials available. I know Inventor 10 has a plywood color for parts, and you could loft or extrude the part you want.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 25-12-2006, 23:07
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
As far as I know, the only way to "bend" is in the sheet metal environment. If the plywood is bent by a certain angle with a constant radius (I guess that would be very unlikely), you could make sheet metal parts and change the material.
Lofting surfaces would probably be the best way to go.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 26-12-2006, 01:42
CraigHickman
Posts: n/a
Lofting is the best way to go. Either that, or just design it into the assembly from a side view on the bend, which may end up more exact. Sheet metal would work, but it'd be easier once Inv. 12 hits, where they'll fix sheet metal to make ti work better.
Unread 26-12-2006, 16:28
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
I don't think you can do it in Inventor but you can do it in SolidWorks and now that SoldiWorks is availible to teams...
Flexible shafts working with CIMs mechanicalbrain Motors 8 07-07-2006 23:38
Flexible, Bendable Rod blue_crew Technical Discussion 7 30-03-2006 19:18
Super flexible Wire want2modmygt Electrical 10 18-01-2006 18:39
Flexible cable management Doug G Electrical 12 10-11-2005 14:04
Where to get lightweight flexible coupling? sanddrag Technical Discussion 3 20-01-2005 01:22
