Go to Post There is no safe place on a FRC robot. - IndySam [more]
Unread 28-12-2006, 15:13
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: Coefficient of Friction
If you have samples of both materials you could do a simple test to get an answer probably not most accurate but better than nothing.
If you have a smaller piece of one of the materials and put it towards the end of a longer piece of the other and raise that end until it begins to slide down at a constant rate. The tangent of the angle would be your coefficient of kinetic friction because at that angle the parallel force of gravity is equal to the force of kinetic friction. This paper provides a better explanation of why it is.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Coefficients of Friction JoelP Technical Discussion 19 28-05-2006 15:54
We attempt to work out the coefficient of drag on a boring sunday afternoon Bongle Math and Science 6 17-04-2006 08:04
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
Skyway Coefficient of Friction HPA_Robotics_13 Kit & Additional Hardware 1 25-01-2005 06:26
Coefficient of Frictions mzitz2k Technical Discussion 15 06-01-2004 20:16
