Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
Unread 28-12-2006, 15:41
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: Coefficient of Friction
Originally Posted by VEN View Post
can i take chromium on chromium friction and copper on copper friction and average it out?
I don't think that will work ... based on information from the table (website) referenced above:
Static Friction example:
Copper / Copper - 1.0 (my source "Marks Handbook" shows 1.21)
Mild Steel / Mild Steel - .74
Average would be .87, table says (Copper / Mild Steel) .53
Cast Iron / Cast Iron - 1.1
Average - 1.05, table says 1.05 (WOW !) - except my source says Cu/Cu: 1.21
Anyway, that doesn't seem to be a reliable way to estimate the friction coefficient. Also, I am sure you are aware that MANY factors can affect your actual friction. Surface finish/roughness, Lubrication, Contamination, Oxidation ...
Your best bet is to experiment with samples of the material you are interested in and collect your own data (as Imajie just posted ).
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 28-12-2006, 19:27
Dick Linn's Avatar
no team (Synergy)
I second the experimental approach. Too many variables...
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 28-12-2006, 20:02
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I should have paid more attention in physics.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 28-12-2006, 20:04
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Just make a test with ditance sensors =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 28-12-2006, 20:40
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Thanks for the input guys
Unread 30-12-2006, 18:36
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Although I'm not sure how accurate this site is, it has Cu on Cr under "Coefficient of Friction" > "Table of friction Values for elements". Also it has some links at the bottom you may want to explore. Good Luck!
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Coefficients of Friction JoelP Technical Discussion 19 28-05-2006 15:54
We attempt to work out the coefficient of drag on a boring sunday afternoon Bongle Math and Science 6 17-04-2006 08:04
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
Skyway Coefficient of Friction HPA_Robotics_13 Kit & Additional Hardware 1 25-01-2005 06:26
Coefficient of Frictions mzitz2k Technical Discussion 15 06-01-2004 20:16
