Go to Post So, we should have respect for each other regardless of whether we are building our robot with a Waterjet or a Hacksaw. Construction methods will vary widely, but honoring your competitors should be universal. - OZ_341 [more]
Unread 28-12-2006, 12:32
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Coefficient of Friction
Does anyone know any good websites to find the coefficient of friction of certain materials in contact? I'm mainly looking for copper on chormium. I am assuming it would be less than copper on steel which is .36 mu
Unread 28-12-2006, 14:29
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Coefficient of Friction
I found alot of other values here but cant seem to find those two together.
Unread 28-12-2006, 14:50
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Yep, I found that one too, and for some reason they don't have kinetic friction for chromium on chromium...just static
Unread 28-12-2006, 14:58
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
can i take chromium on chromium friction and copper on copper friction and average it out?
Unread 28-12-2006, 15:13
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
If you have samples of both materials you could do a simple test to get an answer probably not most accurate but better than nothing.
If you have a smaller piece of one of the materials and put it towards the end of a longer piece of the other and raise that end until it begins to slide down at a constant rate. The tangent of the angle would be your coefficient of kinetic friction because at that angle the parallel force of gravity is equal to the force of kinetic friction. This paper provides a better explanation of why it is.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 28-12-2006, 15:41
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
I don't think that will work ... based on information from the table (website) referenced above:
Static Friction example:
Copper / Copper - 1.0 (my source "Marks Handbook" shows 1.21)
Mild Steel / Mild Steel - .74
Average would be .87, table says (Copper / Mild Steel) .53
Cast Iron / Cast Iron - 1.1
Average - 1.05, table says 1.05 (WOW !) - except my source says Cu/Cu: 1.21
Anyway, that doesn't seem to be a reliable way to estimate the friction coefficient. Also, I am sure you are aware that MANY factors can affect your actual friction. Surface finish/roughness, Lubrication, Contamination, Oxidation ...
Your best bet is to experiment with samples of the material you are interested in and collect your own data (as Imajie just posted ).
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 28-12-2006, 19:27
Dick Linn's Avatar
no team (Synergy)
I second the experimental approach. Too many variables...
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 28-12-2006, 20:02
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I should have paid more attention in physics.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 28-12-2006, 20:04
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Just make a test with ditance sensors =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 28-12-2006, 20:40
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Thanks for the input guys
Unread 30-12-2006, 18:36
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Although I'm not sure how accurate this site is, it has Cu on Cr under "Coefficient of Friction" > "Table of friction Values for elements". Also it has some links at the bottom you may want to explore. Good Luck!
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Coefficients of Friction JoelP Technical Discussion 19 28-05-2006 15:54
We attempt to work out the coefficient of drag on a boring sunday afternoon Bongle Math and Science 6 17-04-2006 08:04
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
Skyway Coefficient of Friction HPA_Robotics_13 Kit & Additional Hardware 1 25-01-2005 06:26
Coefficient of Frictions mzitz2k Technical Discussion 15 06-01-2004 20:16
