Go to Post The next hint will be game hint #3. Everyone will go crazy trying to figure out which of the fake hints was hint #2. - Joe Ross [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-12-2006, 14:50
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: KOP gearbox?
I noticed the changes to the IFI web site a day or so ago while checking to see if the new IFI wheels had been released yet. What puzzles me is that all of the "Out of Stock - No More This Year" items have been changed to "Check back after 1/8/07" except for the breaker panel, the camera, and the servos. I wonder what this means? I sure hope the breaker panel isn't going away. It is just so much cleaner to use than all of the separate terminal and fuse blocks even if it is optional and we have to buy it. I wouldn't be surprized if the camera was upgraded again this year and they went to a different model servo. I just find it odd that in all the locations on the IFI web site these 3 items are distinctly different than everything else.
Unread 21-12-2006, 15:24
Billfred's Avatar
Billfred Billfred is online now
Re: KOP gearbox?
Originally Posted by Peter Matteson View Post
Rumor is there's a new kitbot and trannies this year.
I've also heard that same rumor, at least in the transmission department. Given FIRST's preference to save money where they can, it seems entirely plausible that FIRST found a cheaper way of going about it. Considering that AndyMark was able to undercut IFI's street price on similar single-speed transmissions by a full third, I put some stock in this idea. (There are dozens of other factors here that I'm ignoring, mind you.)
Unread 21-12-2006, 15:37
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: KOP gearbox?
Its very possible that they are usingAndyMark or other cheaper solution. If each team gets 2 of them, there are atleast 1000 teamd and they can make them $50 cheaper that is alot of money.
2x50x1000 = 100,000
Unread 21-12-2006, 18:45
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: KOP gearbox?
It could just be a minor modification to the kitbot and/or KoP transmissions, I'm not freaking out about anything
Unread 28-12-2006, 21:29
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: KOP gearbox?
If they are drastically changing the KOP gearbox I would be surprised. The tooling that they would need to make those would be very expensive and couldn't possibly be worn out after only two years of use. Most of the cost of those gear boxes was already invested, so cost reducing them would be either stupid or very hard.
Of course there tooling could have a shorter life time than I thought but it seems silly to buy tooling to make only 4000 or so of an item.
Just a thought
Unread 28-12-2006, 21:36
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: KOP gearbox?
if my memory serves me correctly the sane thing happened before last yeas kickoff. they all said "check back after (insert kickoff day here)".
I'm not worried about any major changes
/forest
Unread 28-12-2006, 22:28
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: KOP gearbox?
Originally Posted by Donut View Post
The whole control system (radio modems, Robot Controller, and Operator Interface) all say this as well; maybe it is changing?
All the motors are still listed for sale; but the CMUCAM, pneumatic storage tanks, and fuse panels all say to check back. Maybe a new fuse panel, a newer CMUCAM, or pneumatics are on the way?
Well, at ramp riot, for the first half of the day the blue alliance would test out the new prototype IFI radios, so I wouldn't be really surprised if there was some other new stuff as well.
Unread 04-01-2007, 19:09
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: KOP gearbox?
There were new radios?
Unread 04-01-2007, 19:29
in between teams
AKA: Luke Van Oort
Re: KOP gearbox?
If you click 'System Overview' on the IFI site you the kitbot and transmission available. A Freudian slip? Or just an accident?
I believe these radios were tested at IRI in '05 as well.
Team 1219: 2009 - Mentor
Unread 04-01-2007, 19:33
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: KOP gearbox?
The radios that we tested at ramp riot were hand-soldered bread boards in a plastic hobby box. As far As I know, they were made earlier this year and half of them actually failed at ramp riot due to defective components.
Unread 04-01-2007, 20:22
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: KOP gearbox?
One guess that I have is that maybe they are changing the output shaft of the transmission to english measurements rather than metric. This would be a very welcome change since its no fin having to ream out hardened steel for the sprockets.
By the way, check out the motors on this page (Robot Marketplace) and their prices. The door motor and window motors are there, as well as some cheap motors that perhaps will be in the KOP. What do you think?
http://www.robotcombat.com/marketplace_motors_ame.html
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 04-01-2007, 21:18
DonRotolo's Avatar
Back to humble
FRC #0832
Wink Re: KOP gearbox?
Wise advice. Maybe they're changing the 1/4" holes to 33/128" diameter, just to annoy me? And 37/64" spacing? They'd have to move the holes on the transmission then....
Don
Unread 05-01-2007, 03:25
Re: KOP gearbox?
I think we will see a totally new transmission. AndyMark, maybe?
Unread 05-01-2007, 09:49
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: KOP gearbox?
I love the AM transmission and unless the GDC comes up with a huge curveball we will be using them again this year.
I just don't see AM being able to produce a couple thousand transmissions for the KOP and then who knows how many spares.
Unread 05-01-2007, 10:02
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: KOP gearbox?
If the transmission is replaced I don'e see first giving us an item that forces everyone to have pnuematics. I also don't see them going with something that requires that type of machining the AndyMark needs. When you're producing ~2500 units you don't want to have to add dog patterns etc. to gears.
Thank-you 294 & 67
www.bobcatrobotics.org
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Making the KOP gearbox shift sanddrag Technical Discussion 4 26-03-2006 23:27
KOP gearbox weight dan_h Kit & Additional Hardware 1 22-02-2006 18:15
Need KOP Gearbox Tom Bottiglieri General Forum 4 01-02-2005 15:35
Looking for KoP Drill motor gearbox parts Max Lobovsky Kit & Additional Hardware 2 09-08-2004 20:06
