Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #31   Spotlight this post!
Unread 30-10-2006, 12:00
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: 2007 Robot Controller
For all of you who want USB because your laptop doesn't have any serial ports. Here is some inside info.
These rule! : CARDBUS / PCMCIA - RS232 Cards
They are insanely fast compared to USB to RS-232.
  #32   Spotlight this post!
Unread 30-10-2006, 18:14
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by BrianBSL
c) IEEE1394 isn't nearly as standard on PC's as USB
PC's maybe... i've seen quite a few laptops with them though. Anyhow it was just a thought...
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
  #33   Spotlight this post!
Unread 06-11-2006, 17:40
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
> There isn't a computer that can be used for programming that doesn't have USB support
My old Pentium 1 begs to differ... And it's much faster than the 486 we used last year, too.
  #34   Spotlight this post!
Unread 29-12-2006, 13:18
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I used to be on the bandwagon that wanted a USB interface.
However much a USB interface would benefit those doing solely IFI programming, it would be detrimental to those teams using off-board processors. Right now there are two ways to get information to the IFI board during a game. The program port and the TTL port. Unless you feel like designing a pass-through system so you can use your system and the camera on the TTL port, the other option is using the program port.
I mean I guess we could just use a USB->Serial converter, but I'd rather have slow programming time than slow data transmission.
http://www.mikesorrenti.com/
  #35   Spotlight this post!
Unread 29-12-2006, 13:24
ThomasP's Avatar
ThomasP ThomasP is offline
FRC #1255 (Blarglefish)
ThomasP is just really niceThomasP is just really niceThomasP is just really niceThomasP is just really nice
Send a message via AIM to ThomasP
The new controller is going to be Java based.
  #36   Spotlight this post!
Unread 29-12-2006, 13:40
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I almost spit my Mountain Dew out reading that.
  #37   Spotlight this post!
Unread 29-12-2006, 13:47
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Yeah, i really hope they dont do that..
And to the post above that about needing another serial line for co processing, they could have two ttl ports and a mini usb just for programming...
  #38   Spotlight this post!
Unread 29-12-2006, 13:49
The new controller is going to be exactly the same as the old controller. They may upgrade the PIC again, seeing as there was so many problems with the 8722.
  #39   Spotlight this post!
Unread 29-12-2006, 13:51
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
I heared that last year's controller has some major isues with gyro...
Some teams reported they gyro had actually burned their RC, so it is probably one of the things that gonna be cahnged..
Onboard radio would be awesome cause personnlay, we had one friendly match last year with no robot functioning' cause the Radio in came out of the RC, wich wouldnt have happened if we had it onboard...
USB's would be an awesome addition to the RC, cause i remember having many problems with that last year,like bringing a laptop wich doesnt support serial, but only USB, and then having to carry around with a huge Desktop computer and a monitor is not really fun...
Also, maybe they will change the OI too, having it supported with USB ins, so we can use much better joystics and other controllers, without having to switch from USB to Serial...
Getting a 9 pin cable was also a bit of aproblem last year, with USB, stuff will be much easier, as its used everywhere and there are like 10 of them in each house. At least 10...
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
  #40   Spotlight this post!
Unread 29-12-2006, 13:56
ThomasP's Avatar
What's wrong with Java?
CollegeBoard uses Java for the AP Computer Science exam and schools with a FIRST team are likely to have an AP Computer Science class... there aren't many extreme syntax differences between C and Java but using a language that the average HS computer science student is familiar with would probably spark more interest.
  #41   Spotlight this post!
Unread 29-12-2006, 14:07
Team 2021 Captain
AKA: Chris Davidson
Buy a USB to serial converter. I have seen people bring desktops to competiton and its a huge waste of pit area.
  #42   Spotlight this post!
Unread 29-12-2006, 14:08
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Yeah i took AP CS last year, idk i guess its just a preference, i would just prefer C
  #43   Spotlight this post!
Unread 29-12-2006, 14:11
Team 2021 Captain
AKA: Chris Davidson
Java doesnt run on PICs by default. Plus Microchip is a sponsor of FIRST. I think that they hope with there donation of Mplab that they assume some people will grow to use and like it and then use PICs and there C compiler for personal and buisness projects..
  #44   Spotlight this post!
Unread 29-12-2006, 14:18
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 21 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
on board radio would be awesome cause personnlay, we had one friendly match last year with no robot functioning' cause the Radio in came out of the RC, which wouldn't have happened if we had it on board...
Word of advice: make sure to check and tighten your radio connection on the processor before every match. It also doesn't hurt to check and see if any of your pwm cables are loose, and that the backup battery is securely fastened. There's nothing worse than being in the middle of a match and suddenly getting no response from a motor/sensor, or the entire robot as a whole if the radio comes loose.
Well you see, the thing is, that they have been working so hard developing and trying to perfect EasyC Pro, that if they switched over to Java, then they would have to start all over with EasyJava. And rumor has it that banana sensors don't quite work the right way in java.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
  #45   Spotlight this post!
Unread 29-12-2006, 14:22
Java isnt built to run on small embedded devices. The main point of Java is to provide cross platform compatibility. When you compile a Java program, it does not compile to straight machine code, as a C program does. It compiles to whats called Java Byte Code, which then has to be run through an interpreter to be turned into machine code your processor can understand. Based on your system (Windows, Mac OS, Linux, UNIX, etc..) you will need a different interpreter. We are all using the same system in FIRST, so there is no need for that level of abstraction. Java is one of the slowest languages out there, and when developing for embedded devices you want to strive for speed and efficiency.
The reason AP CS is taught in Java is for its wide range of compatibility, and the fact it is an object oriented language which is built off the idea of classes. While your final product may be slow and limited, the programming methods you must use to create applications is very robust and practical. The AP CS class doesn't exist to teach you Java, but rather to teach good programming techniques in an object oriented language.
Robot Controller NotaNerd Control System 6 04-11-2004 16:53
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
Robot Controller Josh Hambright Electrical 2 23-01-2003 13:36
Robot Controller srjjs Rules/Strategy 4 08-01-2003 19:08
Robot Controller archiver 2000 3 23-06-2002 22:54
