Go to Post Oh, the magic smoke will just make make it seem a bit more like Christmas. - CJO [more]
Unread 30-12-2006, 01:33
MAteo9944's Avatar
MAteo9944 MAteo9944 is offline
Knowledge Sponge
AKA: Matt Carroll
FRC #1379 (Gear Devils)
MAteo9944 will become famous soon enough
Send a message via AIM to MAteo9944
pic: Shaft Drive Bearing Blocks
Unread 30-12-2006, 01:34
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Re: pic: Shaft Drive Bearing Blocks
Why cant you use chain instead of having a shaft all the way down your drive system?
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 30-12-2006, 01:50
MAteo9944's Avatar
Knowledge Sponge
AKA: Matt Carroll
I believe(haven't actually calculated) that the shafting will end up weighing about the same as the chain required to drive a similar system.
Last year I got annoyed with tensioning chain.
If I do it properly I won't have to worry about it breaking(though the same goes for a properly designed chain system).
It is different. Its cool.
Why not(seriously I would like to be critiqued. Though I probably don't have to ask on CD)?
I just checked out the weight issue a little bit. #35 rollerchain is about .275 lbs/foot
If you use 6 feet that is about 1.25 lbs
the shafting in this system only weighs about .25 lbs
If you went with #25 like a lot of teams the the chain is lighter
I still havn't looked into sprockets vs miter gear weight
Unread 30-12-2006, 01:56
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
I'm curious as to the advantages this method provides over more traditional chain drive systems, other than being really different and cool.
The Sciborgs
2006 NYC Engineering Inspiration Award Winner
2007 NJ Regional Finalist
2007 NYC Regional Best Website Award
2007 NYC Regional Chairman's Award Winner
Unread 30-12-2006, 02:31
I would not want to have to fix that thing...
Dropping a chain is one thing. Swapping out a whole shafting system might turn out to be another.
Unread 30-12-2006, 04:03
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
The point is to come up with a design so durable that failure will not be a factor to worry about in competition. I like this design
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 30-12-2006, 04:09
FRC #0701 (RoboVikes)
I know Team 1097 did something very similar to this in 2005. It took them almost the entire 6 weeks getting the base running perfectly, but it was one heck of a bot, they won the Davis Regional.
Even with the flexible shaft coupling your frame needs to be welded very straight, and should be sturdy enough not to bend. 1097 had everything very precisely machined and put together.
Is the transmissions efficiency as good as a well tensioned/aligned chain drive? I take it there are several mitre gears, as well as shaft misalignments that all add up.
Team 701
Unread 30-12-2006, 10:44
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
the only thing that scares me about this is those little bitty gears direct driving those moderately sized wheels., but what do I know Im not a meche. good luck on that drive system though
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 30-12-2006, 11:17
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
It looks like you are machining your own wheels. If that's the case, why don't you just make a center wheel that is slightly bigger that the two outer ones. The speed of that wheel will be negligibly higher than the outer two, but it will allow you to have a standard pillow block in there, as opposed to the IGUS ones. This could make for a possibly more robust drive setup, as some teams had problems with those plastic IGUS bearings last year.
BEN
Unread 30-12-2006, 11:23
MAteo9944's Avatar
Knowledge Sponge
AKA: Matt Carroll
In the case of a failure I plan on having an extra side module pre-assembled to swap out.
Unread 30-12-2006, 11:33
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I always like the idea of a shaft drive. It can be quieter and requires less space and can be more reliable when put together well. I like the bearing support at the drive wheels. Some additional considerations: The drive pinion is ok, but should probably go to a larger gear, use the final gearing as a factor for the transmission. Also, you should consider incorporating a thrust bearing to absorb axial thrust. One other consideration. long shafts need more bearings for support. Have you looked into using a hollow shaft? There is always a certain amount of torque involved which a hollow shaft can absorb better without breaking. Or if you want to get really fancy you can use a quill shaft (you'll have to look it up). A quill shaft is essentially a shaft within a shaft that extends the effective length of a shaft. Length is good because that, too, increases torque flexion which reduces breakage.
Unread 30-12-2006, 11:37
MAteo9944's Avatar
Knowledge Sponge
AKA: Matt Carroll
BEN
This is actually something that I considered for a while, but one of my team's ME mentors talked me out of it. I can't figure out if it would be a problem or not. I probably need to test it out and see. If anyone has experience with this could you please help me out?
As for the IGUS bearings, they should be fine. They are not under too much load from the miter gears. We are using conventional ball bearings where there are higher loads.
Unread 30-12-2006, 11:52
MAteo9944's Avatar
Knowledge Sponge
AKA: Matt Carroll
I went with the solid shafts so that I could use shaft keys instead of set screws. I do like the idea of quill shafts. I will have to look into them.
Hopefully one day soon I can get hold of an ME for long enough to go over all of the calculations for the strength of the system. As of now the design is still without the support of the calculations, so the sizes and types of components are subject to change.
Unread 30-12-2006, 13:01
REVving up for a new season
FRC #2848 (All-sparks)
Efficiency might be your worst nightmare with this system.
Chain & Belt Efficiency ~ 95% - 98%
Spur Gears Efficiency ~ 95% - 98%
Bevel Gears Efficiency ~ 90% - 95%
Planetary Gears Efficiency ~ 80% - 90%
Efficiencies multiply for every stage in your gearbox, so for your drive you have spur>planetary>bevel(x2) assuming that your gearboxes are that the top of efficiency you would be getting .98*.95*.90*.90= ~75.4% efficient at transferring torque. This also does not take into account the effects of torsion of your drive shaft on the efficiency. I like the idea and how different it is in application, but sometimes being innovative for no reasons can have adverse effects. That being said I would love to see this drive work, but I would be hesitant to build this for the competition season without building a prototype drive in the off season.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 30-12-2006, 14:00
John C's Avatar
John C John C is offline
FRC #0075 (RoboRaiders)
Team Role: Driver
John C has a spectacular aura aboutJohn C has a spectacular aura about
My team has also designed a similar system. There is one thing you may want to take into consideration. In our design we use spider couplings in the driveshaft to allow for slight misalignments in the bearing position. This was important for us because if the robot frame becomes bent slightly in any way it will bind the shaft. Ill post the drawings after our next meeting on Tuesday so you can see where they are located.
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
