Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 30-12-2006, 16:27
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Re: Code::Blocks IDE interface (Tutorial/Makefile)
Originally Posted by JBotAlan View Post
I take it I have to have gcc installed?
It auto-detected the gcc install that came with Bloodshed Dev-C++ and was using the mingw32-make.exe from there, but I still kept getting the error:
mingw32-make.exe: *** No rule to make target `obj.8722\cal.o', needed by `PIC18F8722.hex'.  Stop.
Process terminated with status 1 (0 minutes, 0 seconds)
0 errors, 0 warnings
I'm not sure what this means. I'm going to check everything over again, but I doubt I am going to get it myself because I'm a n00b...
JBot
EDIT: It seems to be looking for the compiler chosen in the dropdown box. I can't find a way to override this and it seems that...HOLD on a SEC! I think I just answered my own question...
EDIT AGAIN: What do I set for the Make: path for the compiler settings? It doesn't look like C18 even has make packaged with it...
EDIT AGAIN AGAIN: Now I got it to run mcc18 at least, but now it gave me something like 30 errors...I'm starting to give up...
If you could post the errors, I'd be glad to help out. Also, CmptrGk, thanks, I'll add the name change into the directions above.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Using Eclipse IDE & makefile as MPLAB replacement RoboPhantom Programming 0 27-02-2005 19:05
2005 code and IDE compatability? Phil Roth Programming 4 08-01-2005 22:30
Operator Interface code RiotingNerd Programming 5 07-02-2004 21:13
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
