Go to Post first post and the FRC "well what is a stick" comes in. Toothpick, does it need to be round, does a carbon fiber chain of Buckie balls count as a stick. CD posters are sooooo predictable. - Foster [more]
Unread 31-12-2006, 14:24
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Number of lines of code in user_routines.c
Hey guys!
My code is HUGE!! .. i mean huge.. well at least i think it is just an overall question for all u guys out there programming this year.. my code is nearly 800 lines of code... including comments.. My question to u guys is.. 'How many lines of code does ur program have just for user_routines.c (including side files)?'
Just cuz im working on my camera code.. and went from 400 to 700....... ima bad programmer... well not really... i just write long code! but then i end up breaking it down... if yu could let me noe that would be great!
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 31-12-2006, 14:41
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Number of liines of code in user_routines.c
I wouldn't worry about it. Our "user" code from last year was 7000 lines, and that was the simplest robot we've had in years.
Unread 31-12-2006, 14:58
AKA: !!Mitch!!
FRC #1392
wow! 7000? ok im good thxs getting scared that mine was gettin too long
Unread 31-12-2006, 15:53
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Yeah under a 1000 isnt bad. Also it has to do with how you code. Theres all sorts of ways to cut number of lines in half without changing anything.
Example
PHP Code:
for(blah){
junk();
instead of
PHP Code:
for(blah)
junk();
cuts out 1 line. Its all how you liek to do it.
Unread 31-12-2006, 16:08
AKA: !!Mitch!!
FRC #1392
Originally Posted by chris31 View Post
PHP Code:
for(blah)
junk();
I mostly do it this way... and i also include all the brackets... even though sometimes you dont have too..
Unread 31-12-2006, 16:10
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Yeah, depending on your style of coding and how many comments you actually add, the lines can vary tremendously. What's more important is the actual amount of data space you use. If you're using MPLAB (and I'm assuming you are), go to View->Memory Usage Gauge, and this will tell you both the amount of code and variable space you're using.
We overflowed the 2005 processor trying to get the camera and a driver perspective drive system with a gyro working. Last year we ended up using about 1/5 of the available space.
Unread 31-12-2006, 16:12
FRC #0701 (RoboVikes)
So assuming some one uses a very inefficient coding style i.e something like this:
int values[3];
for(int i =0; i<=2; i ++)
    switch i
    case 0:
    values[0] = 0;
    case 1:
    values[1] = 0;
    case 2:
    values[2] = 0;
versus:
for (int i =0; i<=2, i++)
     values[i] = 0;
The modern compiler should still spit out the same machine code correct?
Team 701
Unread 31-12-2006, 17:05
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
In an ideal world, yes, the compiler should do about the same thing. However, we're talking about MPLAB's compiler here, and it's far from "ideal". Something tells me even GCC would have difficulty optimizing it. My best bet goes to Intel's super-optimizing compiler. It's too bad we can't have something like that for our PICs.
As for code length in user_routines.c? It's only about 400-500. That's because I split my code up into multiple files. In all, I think I've written about 2000 in the pre-season this year. I've also taken the time to write my own camera code as opposed to Kevin's (it's good, just a little drawn out, IMHO).
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 31-12-2006, 17:19
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
great!
The # of lines is kinda irrelevent, they could be blank lines, or comments or stuff
The code from my team last year for FIRST is slightly over 900 lines, and that's before the precompiler includes all the files and stuff.
Don't worry if your code's really large, maybe it's huge cuz it needs to be cuz it does a lot, who knows.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 31-12-2006, 17:49
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
The current code I have for user_routines.c is 111 lines long.
I gutted it (all those Limit_ functions are gone; I never used them) and I haven't put the drive code back in since the rewrite. That's why it's so short. Plus I have the code spread into other files I created, too.
Don't worry about it being long. Worry about it being readable. Being up late in the shop night before ship date you may be tempted to just keep writing, but when you have to decipher it to figure out why autonomous mode did nothing, you will smack yourself if it isn't readable.
JBot
Aren't signatures a bit outdated?
Unread 01-01-2007, 03:54
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Number of lines of code in user_routines.c
It's not code length... it's code functionality.
i believe ours was about 1,200 lines long... and i code in the most space saving style imaginable.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 01-01-2007, 04:36
Back after 4 years off
FRC #5279
Code length in C varies drastically based on style. If you use alot of functions your user_routine.c will be much shorter but you may have a huge header file some where.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 01-01-2007, 09:10
Team 2021 Captain
AKA: Chris Davidson
Basically if your worried about space just remember to use the right data type. No reason to be keeping a counter that goes from 1 to 10 in an int.
position of fleid lines Tachion FIRST Tech Challenge 1 05-12-2005 14:36
field lines Tachion FIRST Tech Challenge 0 15-11-2005 15:46
cruise lines robot180 Chit-Chat 9 29-06-2004 22:03
Extruding Lines Jim Giacchi Inventor 7 21-08-2002 17:30
