Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 30-12-2006, 21:18
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
Re: pic: Shaft Drive Bearing Blocks
Originally Posted by MAteo9944 View Post
I went with the solid shafts so that I could use shaft keys instead of set screws. I do like the idea of quill shafts. I will have to look into them.
Hopefully one day soon I can get hold of an ME for long enough to go over all of the calculations for the strength of the system. As of now the design is still without the support of the calculations, so the sizes and types of components are subject to change.
Cool idea. I like it.
On the keys/set screw thing, I suggest looking into using hex stock rather than round. I know that it will make the build phase harder, but I believe that the advantages gained will be well worth it. The hex gives you six corners to bear the load, and I would think that you could drill quite a bit out of the center without losing much strength. I know hex is used in John Deere hay balers for the main driving shaft, and I have never heard of there being problems with them (not there, at least). JH
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 30-12-2006, 21:22
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Great design. but if the frame flexes chances are something is gonna skip or break. plus under the tremendous forces on that shaft i doubt the bearing blocks will stay in place. If its a flat game this year then it might work but even then the robots still take alot of beating.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 31-12-2006, 01:23
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Yeah this is a neat design something you don't see very often, and there may be some good reasons, the efficieny is one thing, another is what you've addressed above.
It will be significantly important for you to go over the stress strain differentials with an ME. There will be many things you'll have to worry about, one is axial and torsional stresses, make sure the shaft is strong enough so that it can handled the axial stresses over the distance and that your degree of rotation is not very significant, as to where it could cause failure.
Make sure the shock, or impulse, of the robot flying full speed into a wall, or another robot is not transfered through the shaft. And if it is at all transfered make sure that the shaft is robust enough so that absorb the impact plastically without significant deflection and no deformation.
Also important, and quite possibly the easiest thing to overlook. is the frame. Frames over the course of competition have a tendancy to get all bent out of shape, it is often minute, but It does happen. In a system where allignment is paramount for optimum effciency its important that frame flexure is limited. A rigid frame will be important make sure that frame is designed in such a way that deflection is minimum and even slight deformation is avoided.
Looks good tho, I'm excited to see the newer drive style, will love to see how it works out.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 31-12-2006, 08:27
TVan's Avatar
TVan TVan is offline
FRC #0085 (BOB)
TVan is an unknown quantity at this point
Looks great, I would consider a flexible shaft coupling on each side. If it looks like your frame will flex, you would not like teeth on the field
Tim
Unread 31-12-2006, 11:37
Matt,
I know that the drawing may not show the components in correct scale but with this kind of drive there are some significant forces that need to be addressed. The rotational forces on each shaft when pushing or in stall will produce a side force if you think about it. Because of those forces, larger bearings and stiffer blocks are needed relative to other types of drive. Without the extra beef, misalignment and high frictional forces will occur in the bearings and shafts. Think of the construction of a car differential and you will get an idea of the kind of strength you will need.
Unread 31-12-2006, 15:20
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
There's been alot of good engineering concerns (side forces, stress on the shaft, etc...)
Here's one more.
Imagine hitting it with a sledge hammer. Can you get it working again in 5 minutes? Can you get a chain drive working again in 5 minutes?
Brian Graham
Unread 31-12-2006, 17:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How about mounting both bearings on either side of one support, and get rid of the othe support? it would save some weight, and should give adequate strength to hold the gear in alignment.
Unread 31-12-2006, 19:29
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Great work on your drive train system! One thing to think about that I thought of... How about making a worm gear system. I think this would be more reliable than the one that you currently have, and you will have much greater control of your robot. The only thing is that you probably would want a fairly small gear on the axle that goes to the wheel.
Just my $0.02...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 31-12-2006, 20:10
MAteo9944's Avatar
MAteo9944 MAteo9944 is offline
Knowledge Sponge
AKA: Matt Carroll
FRC #1379 (Gear Devils)
MAteo9944 will become famous soon enough
Send a message via AIM to MAteo9944
Just my $0.02...
The problem with worm gears is in the efficiency. They are usually about 60-70% efficient as opposed to the 95% efficiency of a miter gear. Some worm gears are even as low as 20% though I have also seen 98% reported.
Unread 31-12-2006, 22:27
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Depending on the game and strategy, the resistance of worm gears to being back driven may be advantageous, or a significant disadvantage. However, I think it would take a lot of strategy advantage to make up for the loss in efficiency.
And it would make it about impossible to push the robot around without turning it on and having the controls. Since it usually has to go in the back of my truck to go to demos, etc. I would really hate that
Unread 01-01-2007, 11:22
RyanN's Avatar
RyanN
I was not sure of the efficiency of a worm gear system. I did not analyze how a worm gear system would be disadvantageous to a team and only looked at the advantages. I saw that the robot would be very responsive (Like when the driver would let go of the joysticks, it would immediately stop) and that other robots could not push my team's robot around, but then you said that it would be a "significant disadvantage," which I can see happening very easily. It would be almost impossible to push a locked robot across the field in the time frame that FIRST gives us during a match. Another disadvantage I found, and I'm not sure if you guys said or not, is that when pushing a robot, the efficiency of the system decreases as friction between the gears increases... I remember this now from my Erector Set when I was a kid. Brings back some memories... Now back to reality; now that I see the disadvantages, I would not use a worm gear system. I guess another advantage that I thought of is that this system would probably be more reliable than our traditional chain method.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
